View Full Version : Buick Distributor suggestions for EFI?
davisca455
01-25-2017, 03:42 PM
Does anyone know if it's possible to convert a '73 Buick distributer to a small cap HEI?
I have a modified stock distributor in the car that will work with the TBI system I'm considering (Holley Terminator), but the ECU wouldn't be able to control spark.
Chris
64duece
02-05-2017, 11:37 AM
I've done a locked out MSD version and used an MSD box (no module required). I've also converted the magnetic to hall effect for a less noise prone setup which also worked well. I'm sure a factory distributor could be reworked with a little time.
Danny Cabral
02-06-2017, 03:06 AM
Does anyone know if it's possible to convert a '73 Buick distributor to a small cap HEI?
Forget the small cap GM HEI computer controlled ignition module. Run an MSD CD ignition box instead.
You can use a Hall-Effect "geartooth" type sensor (LINK (https://www.holley.com/products/fuel_systems/fuel_injection/fuel_injection_components/sensors/parts/554-124)) without installing any magnets.
The Hall-Effect crank sensor is wired as shown in the Holley EFI Wiring Manual:
http://documents.holley.com/techlibrary199r10555rev17.pdf (Holley EFI Wiring Manual - Figure 11, Page 20)
http://forums.holley.com/showthread.php?2590-Magnetic-amp-Hall-Effect-Crank-Cam-Sensor-Setup (Crank & Cam Sensor Setup)
http://forums.holley.com/showthread.php?2577-Synchronizing-Ignition-Timing-Holley-EFI (Ignition Timing Synchronization)
davisca455
02-12-2017, 08:03 PM
Thanks for the help Dennis and Danny.
Much appreciated,
Chris
