    Results 1 to 6 of 6
      NJ
      Custom door panel backing
      Lets just say if I were to build custom door panels? What material do they use as a foundation? Do you just strip the old ones, or is there a specific material used to start from scratch?
      John
      boerne texas
      1/4 '' mdf will do what you want .
      rickk
      www.rickswoodworking.com
      Colorado
      1/8 or1/4" masonite would be an option also. Not as ridgid, will conform to a curved surface a little easier. JMHO
      Brett
      Greenville, IL
      door panel
      I usually use 1/8" ABS plastic. It comes in 4'x8' sheets and is available from almost any plastic company. If you can find it locally you are better off, because shipping is very expensive. If is also available from Miami Corp.. It can be cut by using a utility knife to score it, then bending it to snap it off. Or if you have a jig saw w/ a fairly course blade, you can cut it w/ that. If you move to slow w/ the jig saw it will just melt back together. It can also be heated and molded if needed.
      Good luck
      Joe
      i use all that was said before, plus i use fiberglass to make a mold of the door.
      its all on what your trying to do as to what product to use.
      Aug 2005
      Carson City NV
      door skins
      curt
