    Results 1 to 12 of 12
      Sep 2013
      Country Flag: Finland
      ls3 throttle pedal mounting to 1967 camaro
      Has some one made bracket for the throttle pedal for sale? If not can someone take a picture of their own so i can fabricate my own.
      Mar 2013
      San Jose,CA
      go through DSE.. its about $35 as long as using a c6 style pedal..
      im looking for one myself but for a 2nd gen.. looks like everything out there wont work for my application so far
      LS3 1967 Camaro RS
      Sep 2013
      i have 2013 camaro original pedal, i think that wont work for me. Going to garage tomorrow and start to fabricate my own bracket for the original pedal
      Sep 2010
      Santa Clara, CA
      If you're talking about throttle-by-wire, Ironworks makes a bracket for the 67
      http://www.ironworksspeedandkustom.c...rod/prd336.htm
      Steve
      Sep 2013
      thats something that might work! Thanks for the link! I think im gonna make my own and use that as model etc to start with!
      Sep 2013
      i made my own bracket, just not sure that is it correct hight but gonna hook my seat on to get the feel on the throttle pedal. Gonna take few pictures later if the bracket is ok.
      Mar 2013
      San Jose,CA
      very nice!!!
      LS3 1967 Camaro RS
      Sep 2013
      heres the final product, im gonna take pictures when i mount it.
      I made three holes and bolt this up with those, welded the original holes shut from the firewall.
      Jul 2011
      Nashville/ Tampa
      Looks good, I need to do the same thing at some point.
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
      Sep 2013
      its quite sturdy bracket, its made of 3mm thick steel plate and the legs are also 3mm thick. i welded them on in the back of the throttle plate. By the way, gonna have to remove seat and carpets to make do this. I used brake pedal for measurement, my throttle pedal is about 1,5" lower then brake pedal and 4" apart from brake pedal to throttle pedal. i Run into little trouble when removed the carpet, previous owner had made some patch work on the floor and the toe boards are useless. He had welded galvanised steel plate on top of the rotten one put some sealer **** in there and now gonna remove all that out on weld it. Also the rocker panel ends have rust damage so gonna see how i can fix those up. I think i need to cut the new floor to to get access to the rocker panel ends.
      Jul 2011
      Nashville/ Tampa
      My interior is out so it shouldn't be too hard. My floor is due to be replaced anyway, once I get time it's coming out and I'm going to do a better job with my console. For now though my pedal is just screwed to the firewall. It's in a good place I'd just like to change the angle a bit.
      Feb 2010
      NE Arkansas
      Quote Originally Posted by 408maro View Post
      Have you looked into the scarebird bracket? I just got mine buttoned up this weekend
      My build thread
      http://www.nastyz28.com/forum/showthread.php?t=241037
      Paint Jail Experience
      https://sites.google.com/site/paintjail/home
