    Results 1 to 3 of 3
      Santa Barbara
      How long to install baer brakes at all 4 wheels?
      Car is currently front disc with rear drum. How long of a job is it to convert at all 4 corners with baer setup? Wondering if I should take the time to do it or have it done.
      thanks!
      dennis68 Guest
      The process of converting at the wheels should onlt take anamatuer 4 hours or so, less depending on your degree of experience. The master cylinder/proportioning valve and any hard line modifications or replacement is a bit more time consuming. Again this depends on your level of experience. An advanced level shadetree or professional could do the whole swap with lines in a 8 hour day pretty easily.
      Santa Barbara
      Thanks for the reply. Does the baer kit come with everything needed or should I source anything before taking car in? Brake fluid aside.
