    Results 1 to 4 of 4
      North Carolina
      Brake line question
      This is gonna sound pretty basic but, why do brake lines coil before going into the master cylinder and/or proportioning valve? Is it necessary? I would like to shorten them and straighten them out to clean them up a little. Any possible problems with doing this?
      May 2002
      Northern California
      Some say its to take up the slack to make both front lines equal length. Others say it acts as a shock so the lines don't break at the fittings from the movement that goes on between the body and frame. I say it to make you say huuummmm.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Copenhagen
      Country Flag: Denmark
      Making them equal in length doesn't make a difference. I think it's makes the production of the lines cheaper since "all" the lines are the same.
      Jun 2001
      Newbury Park, CA
      It allows for flexibility and ease of alignment of the lines/fittings to the splitter/MC/proportioning valves. They also allow for MC removal with lines connected to service the booster system.
      The Camaro does not have a loop for extra line, but does have a bend that will allow some flexibility.
      The car has a single line to an AN "T" to the LH frame mount, then a short line to the LH wheel, long line to the RH wheel. No issues.
