View Full Version : Brake line question
69importkilla
11-14-2005, 05:41 PM
This is gonna sound pretty basic but, why do brake lines coil before going into the master cylinder and/or proportioning valve? Is it necessary? I would like to shorten them and straighten them out to clean them up a little. Any possible problems with doing this?
11-14-2005, 06:08 PM
Some say its to take up the slack to make both front lines equal length. Others say it acts as a shock so the lines don't break at the fittings from the movement that goes on between the body and frame. I say it to make you say huuummmm.
E30M30
11-15-2005, 05:27 AM
Making them equal in length doesn't make a difference. I think it's makes the production of the lines cheaper since "all" the lines are the same.
CarlC
11-15-2005, 07:29 AM
It allows for flexibility and ease of alignment of the lines/fittings to the splitter/MC/proportioning valves. They also allow for MC removal with lines connected to service the booster system.
The Camaro does not have a loop for extra line, but does have a bend that will allow some flexibility.
The car has a single line to an AN "T" to the LH frame mount, then a short line to the LH wheel, long line to the RH wheel. No issues.
