View Full Version : Detroit Speed firewall panel
chevyshawn
10-26-2016, 01:22 PM
I'm trying to figure out the best and cleanest way to weld this panel in to smooth the firewall on a 67 Camaro. I've seen pics of the panels being spot welded every inch or so but never fully welded all the way around. The question is do I fully weld the panel in or just spot weld it every half inch all the way around before I bodywork it. Also has anyone used seam sealer smoothed out instead of bondo?
TheJDMan
10-26-2016, 02:20 PM
What do the instructions recommend?
chevyshawn
10-26-2016, 03:06 PM
Was a Craigslist buy, no instructions.
PRRC
10-26-2016, 03:28 PM
completely weld around the panel. Tig if you can. If your going to wire feed. small sections at a time cooling the weld with compressed air as you go.
dhutton
10-26-2016, 04:01 PM
Spot it every 1/2 inch and seal the rest with panel adhesive. I use 3M 8115.
Don
