    Results 1 to 15 of 15
      Jacksonville, FL
      New Dakota Digital HDX gauges
      Got a present from the Fedex guy yesterday. Can't wait to install them in a couple of weeks!
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jun 2006
      TX
      Make sure to take some pics of them installed. I have been looking at those as well.
      Kyle
      Oct 2015
      Western Mass
      I was all ready to pull the trigger on these but I wanted separates; two big gauges (speedo & tach) and four 2-1/16" gauges. They'll be out maybe next year. I'll probably go with New Vintage. But the HDX stuff looks sweet. Please share your install.
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
      May 2011
      Lemoore, CA
      You didn't tell me you got your gauges already....
      May 2007
      Las Vegas
      How about now?
      Rich
      1969 Camaro (in hibernation)
      Jan 2017
      i just installed the exact same ones in my 67 firebird resto mod....i got red lights
      Jacksonville, FL
      Quote Originally Posted by pipebrent View Post
      Red lights?
      Chris
      Jan 2017
      background colour..red or blue and white i believe.....i got the red lights for night...my bad i read the post wrong i installed the VHX dakota guages lol
      Jacksonville, FL
Size:  93.9 KBName:  IMG_0798.JPG
Size:  93.7 KBI was finally able to get them in my car. I was changing from their VHX gauges to the HDX ones. Pretty easy installation and didn't have any issues (other than me not reading the instructions at times ;-)). You can change the gauge backlighting and needles to a rainbow of different colors. You can also have different colors when you turn the lights on. Pretty cool pieces!
      Chris
      Sep 2016
      LA - Lower Alabama
      Any issues with the needles being a little "jumpy?" I put HDX gauges in my '69 camaro, and on the first trip out I noticed the speedo needle operation wasn't as smooth as I expected. Dakota Digital tech support said the needles have two sweep speeds and I was going "just" fast enough for it to switch between the two.
      Wondering if anyone else is seeing the same behavior.
      Jacksonville, FL
      Will tell you this weekend when I drive it.
      Chris
      Feb 2013
      I love my VHX setup but these look extremely cool!!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Houston, TX
      Those gauges are sweet. They address a lot of the short falls that I see with the VHX guages.
      Tu Ho
      Firebird V2-LS swap
      Sep 2016
      LA - Lower Alabama
      Quote Originally Posted by 130fe View Post
      Did you get to drive it this weekend? How was the needle movement?
      Jacksonville, FL
      AU Doc, yes I did drive it this weekend. I did have a slight mph needle flux (2-3 mph)while driving at highway speed. I only noticed it if I looked at them. I set mine up to have the digital MPH # below the tach while cruising. Less things to have to concentrate on LOL. What are you using for your input for the VSS. I am using the OBD BIM module for everything but can't use it for the VSS (my tune wheel/tire/gear ratio are incorrect). I ended up just using the VSS output wire from the PCM and did the measured mile procedure. I never adjusted the sensitivity setting from the default one so I will change it and see if it stabilizes. Did you change your setting? Did it help?
      Rickpaw/Josh, yeah I have had the VHX ones for a couple of years before these and I think they are great. These new ones do address some of the things i didn't like about the VHXs. I like the larger LCD displays and the warning lights for each gauge are in the gauge display (small red light). The black buttons that you toggled on the VHX are now on the gauges. With the new LCD displays, there are 4 modes you can display different readings and scroll through them with just a button push. Overall I am glad I upgraded. I sold my old ones to another Camaro buddy in town who likes them. Win, win for both of us!
      Chris
