View Full Version : Udoit 67 twin turbo camaro
UDOIT
09-25-2016, 03:53 PM
First post on here, but been following some of the builds for over a year. Been working on putting plans together a 67 twin turbo Camaro, 4l80E trans, Chassisworks G-street chassis. Goal is to get 30 mph on the street and 220-230 mph on the Texas Mile type events. Been racing top Alcohol Dragsters, Funny cars and A Nostalgia Nitro Funny car for the past 20 years so this street deal is all new to me. Will have to ask a lot of questions but this site seems to have a lot of talented people giving good advice. If I can figure out how to post pictures I will keep the progress updated. Stared with a rust free 67 which should shorten up the build time. Currently mocking everything and hope to have a rolling chassis by the first of the year.
SD67
09-25-2016, 05:50 PM
Looking forward to seeing the progress, welcome to the site. Working on a 67 myself with some more modest goals and this site has always been good to me.
UDOIT
09-26-2016, 03:47 AM
13231613231913231813231713224413224513223813223913 2240132241132242132243132244132245132246Finally figured out how to upload the pictures. Started removing the floor and getting everything prepped for installing the G-street chassis
UDOIT
09-27-2016, 02:15 PM
132348132348132348Thought I had this posting thing figured out. Don't know how one ended upside down
UDOIT
10-08-2016, 01:18 PM
Anybody have any thoughts on master cylinders? Dual with balancing bar or single with a proportional valve?
the owl
10-08-2016, 01:46 PM
I'm excited to see this build! Any idea what aero upgrades you have to do to hit 230mph?
UDOIT
10-08-2016, 02:30 PM
133160133159133160133159132948132949Still working on the design but were tucking the bumpers, removing drip rails. flush mounted windows Due to the speed were trying to run in the mile and still drive it on the street were trying to make it so the front and rear spoilers interchange. (race version wouldn't be friendly on the street) A mild version for the street and race version with front splitter and rear wing The hard part is designing it so we can make the changes within a couple hours. Working with a aero guy on the grill area also. HP helps also. Will post some renderings once we get them done to get some different opinions, ideals and thoughts.
Mocked up the dry sump pan and pump. Nice piece from Dailey Eng.
UDOIT
10-17-2016, 05:03 AM
Running the Brake and Fire suppression lines thru the frame
andrewb70
10-17-2016, 05:57 AM
Nice build and very nice shop!
Motown 454
10-17-2016, 08:32 AM
Amazing build!
1968CamaroSS_Sam
10-17-2016, 11:39 AM
I am going to love watching this cool build. Thanks for sharing it with us.
UDOIT
10-31-2016, 02:34 AM
Finished welding chassis.
rfalker1
10-31-2016, 10:11 AM
Wow, I have just basically finished mine... Could not imagine going that fast in it... or getting the MPG ! Question I have heard that its not the best idea to smash the 4L80e into 4th while maxed out on boost.
Michaels 69
10-31-2016, 11:00 AM
Nice build, This cars going to be awesome!
UDOIT
10-31-2016, 12:54 PM
To your question on the trans The 4l80E will not take the HP under full boost but I am told that neither will the Trimac. We are having a custom 4l80E built with a lot of billet internals. With that being said, we are running a gear vendors overdrive behind the 4l80E trans. On the speed events we will run the 4l80E in drive and shift the gear vendor which I am told will take the load. On the street we will just run 4l80E in over drive and depending on what rear gear we decide on, we can use a double overdrive. Basically we will run the motor just above idle to get the MPG. (with manual converter lockup) Motor will have a large stroke to help the low end tug on the street. With that being said we will run 2 sets of injectors and 2 fuel complete fuel systems. The street mode will be running on a small set of injectors for the MPG and when the motor needs it, the larger set and secondary fuel system will kick in. My engine guy says he has a 427 LS motor getting 26 MPH so he don't think it a stretch to get 30 MPG As I stated earlier its a goal A lot depends on weight and aero and these are unknown at this point
rfalker1
11-01-2016, 04:07 PM
Thanks for the response! Guess the legend is true!!!
UDOIT
11-06-2016, 12:27 PM
Dailey Dry Sump Pan And Pump
andrewb70
11-06-2016, 01:46 PM
With a lot of power I see no reason to run a 4L80e. I'd run a Powerglide with a GV on it. Gear the rear appropriately for the speed you want to hit. A Powerglide will take a lot less power to drive and save an easy 100 pounds.
UDOIT
11-07-2016, 05:45 AM
You may be right but after several conversations with the engine builder and transmission guy we came to the conclusion that for MPG were looking for the 4L80e would suit the application best We discussed everything from a power glide, turbo 350 400 turbo t0 a lenco drive. The transmission guy first choice was a turbo 400 but we would give up MPG Also a buddy of mine runs a power glide in a 69 twin turbo with a 632 big block 3200# car and has went thru 3 power glides in 2 years and is currently switching to a turbo 400,
Peter Mc Mahon
11-07-2016, 06:16 AM
Interesting build, and nice shop!
UDOIT
11-14-2016, 06:34 AM
134033134034134035
Fitting Roll Cage. It will come off the jig once we get the cage welded in. When we get it off the jig we will install the mock up block with front pulleys and stuff, install the front and start building headers, and running tubing to the intercoolers.
Thanks for the comments on the shop. It was my race shop and am in the process of converting it over to a UDOIT auto club ( which is where the name of the car came from) The ideal is for car guys in the area to be able to join the club and have access to work on or build anything they want in the shop. I furnish tool, lifts, welders, mill lathes, tube bender, notcher, sheet metal brakes, for a rental cost. Shop has infloor heat and fully air condition, lounge, TVs so if you want to anything from hang out, changing tires, oil etc. to building a complete hot rod. The concept is in the St Louis area there are a lot of talented retired guys that are motor heads that after retirement don't have a lot to do. If you get a group of talented guys that want to give advice, help or charge for there services it can be done at a reasonable cost. Already have a chassis guy body and paint guy, machinist and electrical guy on board. Any comments welcome
UDOIT
11-28-2016, 03:19 PM
134413[ATTACH=CONFIG]134414[/ATTACH
Ready to build headers and mount Turbos
UDOIT
12-30-2016, 01:09 PM
135507135508135509[ATTACH=CONFIG] Mocking up headers and Turbos
UDOIT
01-09-2017, 04:15 PM
135893135894135895
1 more piece of the puzzle/
SD67
01-09-2017, 08:29 PM
Looking good, what intake is that?
Bowtie racing
01-10-2017, 02:32 AM
Most impressive body jig I have ever seen. Can you share more pics how you joint the body shell on new frame?
MonzaRacer
01-10-2017, 11:42 AM
OK to chime in here, sweet car. Now let me state that a properly built 4L80E can handle boost once the gear is changed it just cant handle it on the change. Have a local guy who ran both a PATC 4L80E and a 5 spd and 6 spd conversion, and he has ran 1200 hp through both in OD at speed. He used his computer to ramp the boost back up in OD. Not saying I would do it if your already talking GV, but it can handle it at higher speeds as the torque has already peaked.
Centerforce
01-10-2017, 06:15 PM
You made that progress in record time! This is shaping up to be one promising street car.
UDOIT
01-11-2017, 02:39 PM
SD67
Intake is made by Shawn's Custom Alloy His site is not up yet but if you go to his face book page it shows what a talented guy he is. He makes a lot of other stuff for LS too, including valve covers, timing covers, fuel tanks.
Bowtie
Jig is really nothing special. The pictures are on the first page that shows connection points. The Chassisworks pro touring kit uses the original front clip mount ( with a alu spacer instead of rubber) The inter rocker is cut out and the kit comes with a much heaver replacement ( it retains the original pinch weld) the crossmember also ties to the replacement rocker, the cage also ties it all togeather, and the final piece is the floor welds in solid which completes the final package. Hope this explains it and if not let me know and I will take some more pic of what your wanting to see.
Monza
I don't know how you know what the exact amount of power to back out as for what is safe to shift into overdrive but I don't care about tearing stuff because I guessed wrong. You also mentioned your buddy made about 1200 hp Does he run mile runs with the car? I don't plan on backing anything down on the mile run and 1200 hp is quite a bit less than what we are planning on making. I do know the guys running the mile are oiling the overdrive gears to make them live at speed and its not from shifting that was breaking them. Don't forget I'm a drag racer (not a throttle stop guy) and only know one way to get to the end and that's wide open.
Centerforce Time is always a problem (I work out of town 4 days a week) so you know what I am doing with my spare time Got behind at Christmas holidays
because I didn't get the header tubes and stuff ordered before and nobody was open between Christmas and the first of the year. Hope to build the headers in a couple weeks and fit the front bar. So I am about a month behind where I wanted to be but should be able to make that up. Only deadline is I have a date of spring 2018 at Recovery room interiors. As soon as I get the front bar in it will come off the jig and start on body work. I hope to have a nice but usable piece when I am done.
xsboost90
01-11-2017, 07:53 PM
i love your project and the end goal sounds awesome- and much more than i'll ever do. I am interested in your business though as ive heard of garage rentals etc and have always thought this would be awesome. I know the first few i heard of didnt last long but they have come back around more recently and could work. Im thinking some day i would like to do this also....
UDOIT
01-13-2017, 06:07 AM
xs
I hope to have a lot of fun trying to achieve the goals I set. I sure there will be some challenges but that's what I enjoy. The UDOIT also shop has challenges as its hard to market. There is no way you can sell it to the general public. Its a real niche business and if I didn't have the shop, tools and equipment I don't know from a ROI that it would be profitable. I plan on retiring in August so it kind of made sense when I retire to have a business that I enjoy especially with a group of people that can share there talents in clean comfortable well equipped shop. My big problem is I'm not a good salesman and don't do well promoting. Its seems to be really hard to find people that want to make a commitment (people that are consumed with cars that have the time, money and passion) that fits the group of people I'm looking for to join. I know they are out there but they are hard to find them, which is why it almost a person to person basis. I am planning on sponsoring a few car shows and open house to try to get the word out . I think if I can get a one on one and get them to the shop will help make the case to join.
MonzaRacer
01-14-2017, 11:47 AM
SD67
Bowtie
Monza
No what his strategy was he was using timing retard with a shift kill set up, the engine "dies" momentarly on the shift, it is a millisecond "kill" it unloads the driveline for the fraction of a second, thus you never lift, the engine controler does the hard work. It's old trick some race bike builders use to not have to use clutch on shifts.
UDOIT
01-22-2017, 05:15 PM
136370136371136372 working on building headers
UDOIT
01-29-2017, 04:07 PM
136618136619Little more progress
67SSDan
01-31-2017, 07:22 PM
"I started with a rust free..." one post later, everything cut to hell. :cheers: Hahaha, I love it.
Can't wait to see this one come together!
Dan
snichols28
02-01-2017, 09:49 AM
Sweet sweet ride man. Hurry up and get it finished so I can see pictures!
UDOIT
02-12-2017, 02:24 PM
137087137088137089137090
Finished welding and mounting the headers, Installed the front strut bars, fit and welded the watts linkage brackets, Radiator, intercoolers, transmission and rearend next
duvall408w
02-12-2017, 07:38 PM
u mite want to add a front motor plate.Did u look at the flowtech holley turbo headers? They can be had for 200$. 304 ss 1 3/4. I would do 4l80e plenty of people in the 7s running 4l80e.Look at jakes transmissions or rpm transmissions in Anderson ,Indiana.Its not like u are going to run 1k on the street and get any grip and on the strip U shouldnt be going into over drive. Rear gear should be around 325.I have ran several turbo set up's and 4l80e 325 gear is the way to go.Never heard of shifting under boost hurt 4l80e it is a th400 with overdrive. I have never had any issues at 1278 rwhp .great build
duvall408w
02-12-2017, 07:50 PM
what motor turbos u going with? 220 -230 mph is huge. Ur rear gear is going to need to be lower than the 325 i stated and the 4l80e with a manual locking convert would work. Ur hp will need to be 2000+++or more to get to 230.I think the fastest 1/2 mile car was 238 buy a lambo.
Artisan Motoworks Club
02-12-2017, 08:25 PM
great build!!
UDOIT
02-15-2017, 03:22 AM
duvall408w
It does have a front and mid plate, I wanted to build our own headers and I can't see how they can sell a set of 304 ss headers $200 and stay in business very long. I got more than that in the flanges. Haven't decide on rear gears yet. Probably end up with 2 third members to reach both goals. I guess it depends on who you talk to on the 4l80e trans but I was told due to the small dia gears they wouldn't hold to the load (not talking about shifting) with high HP and 230/240 speeds. Some guys are spraying oil directly on the OD gears to make them live. Engine builder at Venom Racing Engines tells me we should have around 1400 HP for the street and around 2400 HP and be safe on the tune. He builds a lot of turbo ls stuff and the head guy familiar with the mile run stuff.
UDOIT
02-18-2017, 02:36 PM
137307137308 Mocked up the rearend and watts linkage
Godbolt
02-18-2017, 03:24 PM
Very nice indeed!
Centerforce
02-21-2017, 06:04 PM
duvall408w
:jawdrop::jawdrop::jawdrop::jawdrop::jawdrop:That is some SERIOUS power! We guess that probably isnt much compared to the nitro drag cars you've dealt with, but no doubt still scary in any street car!
UDOIT
03-03-2017, 03:32 PM
137866[ATTACH=CONFIG]137865[/ATTACH Transmission with Gear Vendors overdrive attatched.
berdunord
03-03-2017, 11:38 PM
impressive ! really nice build
UDOIT
03-06-2017, 04:10 AM
Off the Jig. Transmission and torque arm installed
UDOIT
03-27-2017, 02:42 AM
138629138630 mocked up the radiator and steering
UDOIT
04-24-2017, 03:02 AM
139689139690[attach=config]139691[/attach Installed exhaust side tubing, some sheetmetal, and steering wheel. Hope to intsall the intercoolers and intake side tubing and pedals next weekend
Crestronwizard
04-26-2017, 05:13 AM
Beautiful work!
UDOIT
05-02-2017, 03:30 PM
139883139884139885 Rough fit all the body panels Gaps ended up not being to bad. still need some work when we get it to the body shop Fit the brake pedal/master cylinders. Next up intercoolers and intake tubing
UDOIT
05-08-2017, 03:29 AM
140025140026140027 Fitting the intercoolers
UDOIT
05-15-2017, 04:07 AM
140264140265140266140267 Mounted the intercoolers and installed the intake tubes
UDOIT
06-05-2017, 06:22 AM
140993Last of the turbo tubing fit and now to start welding. Next step is to build the dry sump tank and start routing lines
Centerforce
06-16-2017, 10:35 AM
That dual intercooler setup looks really aggressive and we would guess it probably has a little better response than using one large unit. Nice job!
USAZR1
06-16-2017, 03:50 PM
Does Gear Vendors offer an even heavier duty o/d unit? The ones I've considered purchasing were "limited" to 1,200hp.
UDOIT
06-19-2017, 03:18 AM
141580141581141582 Boxed in the frame where we had to run the intake tubing
Centerforce;
Don't really know what you mean by aggressive but after talking to Bell they thought this would be the best design. They are still not big enough when we crank up the boost but we tried to use the available space that we had and still keep the tubing as simple and efficient as possible.
USAZR1
You may want to check with gear vendors as they advertise on there home page over 2000hp. When we discussed our project with Hughes and Gear vendors they think it will handle the power just fine, Don't know if you follow drag week but Larson makes about 3000 HP and runs high 5,s Lutz does about the same. I was told by Steve at Hughes they only made a couple tweeks to the gear vendor stock unit. No so much with the trans
KB Camaro
06-20-2017, 08:54 PM
awesome build!
UDOIT
08-07-2017, 05:12 AM
First rendering of track version. Still needs a few tweeks
UDOIT
08-14-2017, 08:57 AM
143210 Final Track rendering Street version shortly
UDOIT
08-21-2017, 02:38 AM
143382 Final rendering of Street version, Should take 3 to 4 hours to convert from street version spoiler/wing to track splitter/wing. Off to the Body guy within the next couple of weeks.
UDOIT
10-14-2017, 06:01 AM
Started running the SS lines. Still have to tweek a bit
UDOIT
11-06-2017, 03:38 AM
Working on firewall and transmission tunnel
Motown 454
11-06-2017, 01:04 PM
The stainless lines look good. The firewall is looking good too.
jeff351
11-09-2017, 10:44 PM
Who makes those black clips holding the stainless lines to the chassis?
oleyeller
11-10-2017, 03:33 AM
NotcHead - DSR Fasteners | Parts, Tools & Accessories
http://www.notchead.com
UDOIT
11-20-2017, 03:57 AM
146347146345146346146348146349Finished fitting the tunnel and floor, firewall and dry sump tank
UDOIT
12-11-2017, 06:37 AM
146840146841146842146843 Started working on shaving the drip rails
Build-It-Break-It
12-11-2017, 07:55 AM
Beautiful work. I'm always excited to see updates on your car.
Gmc427
12-12-2017, 11:06 PM
enjoying this build!looking forward to hearing it fireup,regards
Centerforce
12-23-2017, 06:11 PM
That floor looks amazing! Awesome job with the sheet metal fab-keep up the good work!
DT69Cam
12-24-2017, 04:33 AM
Looks great. What fittings did you use with the SS lines at the firewall ?? I would like to do something similar for my power steering. I'm not sure the compression fittings can hold more than 150 PSI though. Thx
dhutton
12-24-2017, 06:32 AM
Pretty sure those are AN flare fittings and not compression fittings. Hopefully someone competent will confirm....
Don
grendel
12-24-2017, 07:20 AM
134033134034134035
Bring it to NH :). I'll retire and you can have my shop.
UDOIT
12-27-2017, 03:21 AM
147377147378147379147380147381147382147383
We are using alu AN flared fittings on the low pressure side of the pump. Still trying to find the correct SS fittings for the high pressure side of the pump. (just not comfortable using alu nuts on the high pressure side although we will test all the lines/fitting to make sure we don't have a leaks prior to engine start up.)
Finished up welding and grinding welds on the tunnel area. Had to modify the trans brace to make room for the gear vendor OD unit and access nuts . Finished most of the work on the drip rails (got a couple small areas to fix where the lead that melted out)
Hope to install the mock up motor for the last time (before fore going to paint) and finish making up the rest of the SS lines, install wheel tubs, fuel tank etc
grendel
12-27-2017, 06:34 AM
Gottashow products should have those. http://gottashow.com/
UDOIT
01-07-2018, 03:18 PM
147603147604147605147606147607147608 Finished fitting wheel tubs, Continuing finishing lines and installing accessories within the engine compartment
UDOIT
01-22-2018, 11:18 AM
148121148122 Started working on air condition lines. Have to drill thru the radiator support and seal weld the tube to the support and seal weld the male fittings to the support. Should make it clean and allow it to be removed
slimjim
01-22-2018, 03:24 PM
I'd give my left nut for one of those intakes by shaun! great work on this
UDOIT
01-28-2018, 04:25 PM
Installing rear pannels, making template for fuel tank slimjim; shawns products are secound to none getting ready to order valve covers, timing cover and valley cover.
UDOIT
02-05-2018, 09:39 AM
Finally got the fittings to finish the SS HP line from the pump to the rack, Finished installing the rear brake ines, and mounted the rotors and calipers to measure flex lines to front brakes
UDOIT
02-18-2018, 05:35 PM
149419149420149421149422149423 Installed emergency brakes on rear, Installed MC reservoirs and run brake lines
UDOIT
02-26-2018, 03:51 AM
149743149744 Finished fitting interior sheetmetal
UDOIT
03-05-2018, 05:17 AM
Mounting Dry Sump tank and welded up condenser lines150545150544150543150546
UDOIT
03-17-2018, 02:15 PM
Mounted dry sump and welded in condenser lines
NoNo
03-19-2018, 03:40 AM
Dang! You work nice & clean... I just re-read the whole build, just for the hell of it, it just makes me smile.
UDOIT
04-01-2018, 03:54 PM
installed 3rd member, fire suppression system, and routing oil lines
UDOIT
04-15-2018, 02:33 PM
Working on body, Installing trunk panels Installed sway bar
Gmc427
04-16-2018, 02:24 AM
very cool build,cant wait to see it finished ,regards
UDOIT
04-23-2018, 05:21 AM
Mounted fuel pumps and run fuel lines Install rear deck lid and made mounts for gas cylinders . Couldn't find a clamp for the dry sump lines that gave me the backside clearance I wanted so I made my own. little cleanup, little polishing and they will good to go to the anodizer
(Once I get my hoses routed correctly.)
UDOIT
05-14-2018, 08:31 AM
152524152523152522152521152520
UDOIT
05-29-2018, 03:52 AM
Installed the C02 bottle and meth pump. Working on building the meth tank. Installed the oil cooler and mocked up oil lines on the right side of the motor. Waiting on the filter mount to finish the oil lines on the left side of the motor. Installed the AC unit starting to mock up lines
UDOIT
06-18-2018, 02:58 AM
Finally l got my fuel tank and started mounting it but of course fittings were install improperly. so it has to go back. Installed the hidden wipers and then installed the fire nozzles in the engine bay153624153623
Chevelle LT1
06-20-2018, 11:19 AM
This has been quite impressive to watch the progression. Nicely done.
UDOIT
07-02-2018, 04:56 AM
Mocked up the meth tank and intake pop offs.
69Phoenix
07-05-2018, 04:29 PM
How do you find time to do all the work on the car and still have a job? Nice work indeed, love the direction you are taking the car.
UDOIT
07-30-2018, 01:12 PM
Finally received the new block. Working on fitting the remote oil filter
rocketrod
07-30-2018, 04:29 PM
Just amazing craftsmanship!
Motown 454
08-02-2018, 07:58 PM
Beautiful work!
UDOIT
08-12-2018, 04:38 PM
155555155554155556155557155558
Finished up the meth tank and plumbing to the pump. Fit the doors and started working on correcting gaps. Installed wheel tubes and will start finishing the rest of the trunk kit. Will put the rear end back in next weekend. Thanks for all the nice comments. Having a real job 4 days a week out of town and working at the shop most all the weekend. Helps the have a understanding wife also. About a month ago I lost my fabricator which will slow the process down quite a bit unless or until I find someone else. If anyone is interested or knows someone looking contact me
Build-It-Break-It
08-12-2018, 08:25 PM
Looking great. Just curious as to why some of the pictures are always so blurry?
UDOIT
08-21-2018, 01:53 AM
155768155769155770 Really don't know why some pic are blurry. They look fine on the computer but sometimes they come out burry. Probably the camera operator. On the ground rolling. Working on Fenders, hood and front end sheet metal
frojoe
08-23-2018, 10:07 AM
This is sick!! Great job on all the packaging.. look forward to the final product.. and maybe some high-quality crisp and clear pics too ;)!!
UDOIT
09-02-2018, 03:49 PM
156167156166156165156168156169156170
Finished fitting all the sheetmetal looks like all the gaps can be fixed with shims but no welding. Working on the flush mounted glass next. Got the intake plumbed for the meth injection Did a mock up on the stock front grill Not going to use it but trying to figure out the front fender due to some front damage on the driver side fender
berdunord
09-03-2018, 05:06 AM
crazy build ! awesome
UDOIT
09-10-2018, 03:08 AM
Fit the front and rear flush mounted glass and front spoiler. Finished up the inlet piping and engine stuff
UDOIT
09-17-2018, 04:20 AM
156579156578156579156578 Working on the cowl area/ dash panel and shifter
UDOIT
10-08-2018, 04:44 AM
Started working on templates to manage the air to the intercooler/radiator and building the pickup and air boxes for the turbo inlets
UDOIT
12-03-2018, 04:47 PM
Mocking up heater, air conditioning lines and fittings Started working on templates to manage the air to the intercooler/radiator and building the pickup and air boxes for the turbo inlets158855158856158857158858158859
UDOIT
01-05-2019, 03:29 PM
Running heater and air condition lines, finished fitting turbo inlet and finished fitting flush mount door handles
Gmc427
01-09-2019, 03:35 AM
take it wheels are just to get rolling?,do you have any more pics of watts link installed?regards
chiva
01-09-2019, 11:47 AM
Looking really good. Nice progress. Keep it up and you’ll have it done in no time!
UDOIT
01-14-2019, 06:24 PM
The tire and wheel combo is just for mock up. Once I decide on final paint and figure out tire/wheel size we can fit within the inter fender well, I will make that decision. There are pic of Watts linkage, on post #3, #37 #42. #37 is the right side support that still needs a support bar installed after I figure where the exhaust is going to be routed. If you need to see anything else let me know and I will take some more pic.
Finished the flush mounted door handles, finished closing up valance to direct the air flow directly into the intercooler160290160291160292
Gmc427
01-15-2019, 02:04 AM
cheers,is the link kit custom or available though retailer?regards
UDOIT
01-15-2019, 04:44 AM
Chassis works sells it. It would require welding on your rear end This was part of their pro touring kit that included their 9" rearend
jjhamlett
01-18-2019, 08:15 AM
very cool project. that dually looks identical to one i sold several years back
UDOIT
02-03-2019, 05:28 PM
very cool project. that dually looks identical to one i sold several years back Bought the truck in Ohio a couple of years ago. Finished the grill. Just need to have it power coated, modifying the headlight buckets. Finishing up the heater and AC lines and installed the fender with the turbo inlet so we can start making the inlet air boxes
UDOIT
03-06-2019, 04:00 PM
Installing isolation plates. Mocking up grill an headlights, installed air intake and filter. Starting to work on cold air boxes and inter fenders. Installing roll pan and moving fuel fill up and removing trunk lock
UDOIT
03-17-2019, 02:37 PM
Finished front grill, moved the fuel fill, tucking the rear bumper, installed the rolled inter fender well lip.
UDOIT
04-13-2019, 03:47 PM
Finishing modifying and fitting rear bumper, Flush mounted electrical kill switch163373163374163375163376163377
andrewb70
04-14-2019, 03:16 PM
Looking good!
Dannnn
04-14-2019, 08:14 PM
149421 Installed emergency brakes on rear, Installed MC reservoirs and run brake lines
I’m getting ready to order a torque arm rear suspension from Chassisworks. Can you give me some info on the rear end specs you ordered? Is that their Floater Axle System with the drum-style parking brake?
http://www.cachassisworks.com/Attachments/DataSheets/85XX-XXX_floateraxle_DS_WEB.pdf
Thanks,Dan
69Phoenix
04-16-2019, 07:19 PM
Fantastic project. Can’t imagine how many hours you have in it. Looking forward to seeing the finished project.
Motown 454
04-16-2019, 08:05 PM
Nice work!
UDOIT
04-18-2019, 03:48 AM
Dan;
I bought the Chassisworks G-street kit. Options I took were torque arm over 4 link, floater axle over normal axles, I took the 35 spline. The kit offers 13,14.15 brakes w/or w/o Emergency parking brake. I took the 15" with emergency brake ( if was to do it over I would probably go with a 14" brake. The 15" which requires at least a 19" wheel limits the size of drag slick you can run). I went with the Strange Alu third member. Let me know if you have any other questions.
Thanks, Jeff
UDOIT
05-28-2019, 03:47 PM
164647164648164649164650164651 finishing up rear spoiler.
ryeguy2006a
05-29-2019, 08:58 AM
That's amazing you made your own spoiler! Looks terrific.
Motown 454
05-29-2019, 05:15 PM
Very Nice!!
UDOIT
06-16-2019, 05:42 PM
Finished installing fuel tank and lines to fuel pumps. Started working on fuel fill and exhaust
spoilersbyrandy
06-22-2019, 06:30 PM
Looking great!
UDOIT
06-30-2019, 02:50 PM
Laying out bracket for muffler/exhaust started running exhaust tubes
UDOIT
07-14-2019, 03:08 PM
165764165765 Finished fitting exhaust to allow for bellypan
UDOIT
09-09-2019, 01:50 PM
167328167329 working on back spacing so I can get wheels ordered. Finished front lower grills
UDOIT
09-29-2019, 04:47 PM
Finished installing the dash bar/side door bars. Also mounted chassis on rotrisery to go to painter in about a month
UDOIT
10-14-2019, 06:00 PM
installing shifter, finished cage and started laying out for paint, anodizing and powercoating168284168285168286
UDOIT
10-31-2019, 04:31 PM
168773168772168771 Headed to do body and paint.
UDOIT
12-03-2019, 01:27 AM
169773169772 Parts started coming back from power coater
- - - Updated - - -
169773169772 Parts started coming back from powder coater
Just 1 More
12-03-2019, 06:54 AM
awesome build
cwylie
12-03-2019, 01:41 PM
Very impressive build!
Dragonfly
12-03-2019, 06:49 PM
Awesome build, I totally dig the front wheel well/lower valance vents, nice touch
Bugzilla
12-03-2019, 08:22 PM
Just keep on posting pictures. I'll be sitting here with the other guys drooling.... :drool:
Canadianwraith
12-11-2019, 02:10 PM
What steering wheel is that? Looks beautiful
UDOIT
12-15-2019, 06:27 PM
NRG 320MM Flat Bottom Shiny Carbon Pt # ST-009 CF/BK
UDOIT
01-21-2020, 05:15 PM
171972171973171974 working on door/quarter aligment, flush mount glass gapps and cleaning up fender/door and a-piller alignment
UDOIT
02-10-2020, 04:52 PM
Finishing metal work and seam sealing
UDOIT
02-27-2020, 03:35 PM
173242173241173240173243173244173245173246
Gmc427
02-28-2020, 02:38 PM
173242173241173240173243173244173245173246no epoxy before filler?
slimjim
02-29-2020, 05:41 AM
Some people don't use it first, I believe some roadstershop builds included. as long as it's sealed good before poly. Either way, rapid progress, coming along well.
UDOIT
03-20-2020, 03:15 PM
One Step closer to paint. Wheels are on the way
andrewb70
03-20-2020, 03:46 PM
Must feel great to be getting closer to getting out of paint jail.
UDOIT
04-09-2020, 03:19 PM
Still not out of paint jail. Now the engine is not finished do to the valves not available do to lockdown. Did receive mounted tires and wheels174618
UDOIT
04-30-2020, 03:59 PM
Just came out of paint jail
SD67
04-30-2020, 06:49 PM
Looks great, what black did you choose?
slimjim
05-01-2020, 04:38 AM
very nice finish!
ryeguy2006a
05-01-2020, 09:05 AM
Wow, that's beautiful!! Nicely done.
rocketrod
05-01-2020, 10:10 AM
Wow! I can't wait to see this come together! This is definitely raising the bar on high end builds!
syborg tt
05-02-2020, 07:12 PM
Incredible build.
454bug
05-03-2020, 11:00 AM
Man, that black paint is a MILE deep! Great project and execution! :headbang:
UDOIT
05-07-2020, 03:00 PM
Finishing sanding and buffing. Building a engine/transmission test stand so we can make sure were leak free once its installed. Hope to finish the stand this weekend and get the car back by next weekend.
UDOIT
05-27-2020, 06:25 PM
Finally going to pick it up Friday
UDOIT
06-04-2020, 04:25 PM
Installing fire supression and mounted shock reserviors
UDOIT
06-22-2020, 06:06 PM
177134177133
UDOIT
07-16-2020, 04:33 PM
177738177737
- - - Updated - - -
177738177737
- - - Updated - - -
177738177737
Andric LibreSinn
07-20-2020, 02:32 PM
This is by far my favorite build on this site. Also the first build I've seen with CA Chassisworks GStreet equiptment on it. Thank you for keeping us updated.
Smooth67
07-21-2020, 09:51 AM
Love that stance!!! Nice build
UDOIT
08-23-2020, 03:26 PM
Last of the ac /heater lines finished air boxes, just have to finish inter fenders
UDOIT
11-07-2020, 02:37 PM
Finally got the engine/ trans on start up stand
Motown 454
11-07-2020, 07:35 PM
Sweet!
Senek67RS
11-09-2020, 01:31 PM
Looks like you switched the valve covers between when the engine was in the car and not that it is on the stand. What valve covers did you switch to, as they look like they will hide the coil packs vs. the ones from SCA that wouldn't. If you are going back to the valve covers from SCA, where are you going to place the coil packs? Thanks!
UDOIT
11-09-2020, 04:14 PM
Scotts Hotrods makes the valve covers. We are trying to go with the hidden coil vc because it makes the package cleaner. A couple issues with using them is that it takes a certain coil and it is not a high performance coil. We had a clearance problem with the rockers which we have solved. (Not wanting to machine the cover), and not sure if the temp will affect then even though they are vented. Didn't like our options on mounting coils but if the hidden ones don't work we will probably make a bracket an mount them to the front chassis support bars
Senek67RS
11-09-2020, 05:12 PM
Thank you! I am running the same valve covers that you had and was looking for a cleaner option as well. We have opted to go behind the engine, but it still looks a little funky with the coil wire and the way that it is routed.
UDOIT
01-04-2021, 03:26 PM
Does anyone make custom bolting for mounting front end sheet metal. I know notchead and Billet Specialities. They make it in Stainless but i thought someone made Titianum ones
rocketrod
01-04-2021, 08:21 PM
Anvil offers a few titanium fasteners.
https://anvilauto.com/collections/individual-bolts-and-washers
UDOIT
02-01-2021, 03:09 PM
184087184088184091184090184092 final assembly
Andric LibreSinn
02-11-2021, 06:23 PM
What are the boxes on the side of the firewall?
UDOIT
02-12-2021, 07:09 AM
Passenger side is the dry sump tank and the one on the driver side is a water/meth tank
UDOIT
02-24-2021, 04:11 PM
Final assembly just need to f inish installing the grill/headlights and interfenders
Motown 454
02-24-2021, 10:56 PM
Damn that's beautiful!
UDOIT
08-06-2021, 03:48 PM
191204191205191206191207191208
[][attach=config]191208[/attach getting close on the wiring
