Page 1 of 8 1 2 3 4 5 6 ... LastLast
Results 1 to 20 of 145
    Jul 2015
    Winfield MO
    Udoit 67 twin turbo camaro
    First post on here, but been following some of the builds for over a year. Been working on putting plans together a 67 twin turbo Camaro, 4l80E trans, Chassisworks G-street chassis. Goal is to get 30 mph on the street and 220-230 mph on the Texas Mile type events. Been racing top Alcohol Dragsters, Funny cars and A Nostalgia Nitro Funny car for the past 20 years so this street deal is all new to me. Will have to ask a lot of questions but this site seems to have a lot of talented people giving good advice. If I can figure out how to post pictures I will keep the progress updated. Stared with a rust free 67 which should shorten up the build time. Currently mocking everything and hope to have a rolling chassis by the first of the year.
    May 2013
    San Diego, CA
    Looking forward to seeing the progress, welcome to the site. Working on a 67 myself with some more modest goals and this site has always been good to me.
    Jul 2015
    Winfield MO
Size:  132.5 KBName:  CAMARO 117.JPG
Size:  97.8 KBName:  CAMARO 115.JPG
Size:  105.8 KBName:  CAMARO 114.JPG
Size:  103.4 KBName:  CAMARO 116.JPG
Size:  101.2 KBName:  CAMARO 118.JPG
Size:  104.5 KBName:  CAMARO 60.2.jpg
Size:  154.2 KBName:  CAMARO 81.JPG
Size:  86.4 KBName:  CAMARO 67.jpg
Size:  155.4 KBName:  CAMARO 121.JPG
Size:  108.2 KBName:  CAMARO 64.jpg
Size:  174.5 KBName:  CAMARO 71.jpg
Size:  170.8 KBName:  CAMARO 116.JPG
Size:  104.5 KBName:  CAMARO 106.JPG
Size:  136.3 KBFinally figured out how to upload the pictures. Started removing the floor and getting everything prepped for installing the G-street chassis
    Jul 2015
    Winfield MO
Size:  130.6 KBName:  IMG_0132.JPG
Size:  130.6 KBThought I had this posting thing figured out. Don't know how one ended upside down
    Jul 2015
    Winfield MO
    Anybody have any thoughts on master cylinders? Dual with balancing bar or single with a proportional valve?
    Feb 2010
    I'm excited to see this build! Any idea what aero upgrades you have to do to hit 230mph?
    Jul 2015
    Winfield MO
Size:  77.6 KBName:  IMG_0158.JPG
Size:  82.5 KBName:  IMG_0159.JPG
Size:  82.5 KBAttachment 132948Attachment 132949Still working on the design but were tucking the bumpers, removing drip rails. flush mounted windows Due to the speed were trying to run in the mile and still drive it on the street were trying to make it so the front and rear spoilers interchange. (race version wouldn't be friendly on the street) A mild version for the street and race version with front splitter and rear wing The hard part is designing it so we can make the changes within a couple hours. Working with a aero guy on the grill area also. HP helps also. Will post some renderings once we get them done to get some different opinions, ideals and thoughts.
    Mocked up the dry sump pan and pump. Nice piece from Dailey Eng.
    Jul 2015
    Winfield MO
    Running the Brake and Fire suppression lines thru the frame
    The Druid City
    Nice build and very nice shop!
    1970 GTO Version 2.0
    Instagram @projectgattago
    Amazing build!
    Apr 2007
    Utah
    I am going to love watching this cool build. Thanks for sharing it with us.
    Sam
    Northern UT.
    '68 Camaro "Bodacious"
    '56 210 2dr "Buckshot"
    Jul 2015
    Winfield MO
    Finished welding chassis.
    Nov 2010
    Wow, I have just basically finished mine... Could not imagine going that fast in it... or getting the MPG ! Question I have heard that its not the best idea to smash the 4L80e into 4th while maxed out on boost.
    68 Camaro RS twin turbo
    Slow Lifted Jeep No TURBO :(
    Randal F
    Oct 2016
    Nice build, This cars going to be awesome!
    Jul 2015
    Winfield MO
    To your question on the trans The 4l80E will not take the HP under full boost but I am told that neither will the Trimac. We are having a custom 4l80E built with a lot of billet internals. With that being said, we are running a gear vendors overdrive behind the 4l80E trans. On the speed events we will run the 4l80E in drive and shift the gear vendor which I am told will take the load. On the street we will just run 4l80E in over drive and depending on what rear gear we decide on, we can use a double overdrive. Basically we will run the motor just above idle to get the MPG. (with manual converter lockup) Motor will have a large stroke to help the low end tug on the street. With that being said we will run 2 sets of injectors and 2 fuel complete fuel systems. The street mode will be running on a small set of injectors for the MPG and when the motor needs it, the larger set and secondary fuel system will kick in. My engine guy says he has a 427 LS motor getting 26 MPH so he don't think it a stretch to get 30 MPG As I stated earlier its a goal A lot depends on weight and aero and these are unknown at this point
    Nov 2010
    Quote Originally Posted by UDOIT View Post
    Thanks for the response! Guess the legend is true!!!
    Randal F
    Jul 2015
    Winfield MO
    Dailey Dry Sump Pan And Pump
    The Druid City
    With a lot of power I see no reason to run a 4L80e. I'd run a Powerglide with a GV on it. Gear the rear appropriately for the speed you want to hit. A Powerglide will take a lot less power to drive and save an easy 100 pounds.
    Jul 2015
    Winfield MO
    You may be right but after several conversations with the engine builder and transmission guy we came to the conclusion that for MPG were looking for the 4L80e would suit the application best We discussed everything from a power glide, turbo 350 400 turbo t0 a lenco drive. The transmission guy first choice was a turbo 400 but we would give up MPG Also a buddy of mine runs a power glide in a 69 twin turbo with a 632 big block 3200# car and has went thru 3 power glides in 2 years and is currently switching to a turbo 400,
    Sep 2011
    Southern Ontario
    Interesting build, and nice shop!
