b17brian
09-14-2016, 04:12 PM
I'm converting my 67 Camaro over to power brakes using the Tuff Stuff 9" dual diaphragm vac booster part #2224NC. The booster push rod lines up on the pedal in between the stock hole for manual brakes and the hole for power brakes. Should I drill a new hole in the pedal where the push rod lines up? Will that give me a satisfactory pedal ratio for power brakes? Will that give too much pedal ratio that it would apply so much force to the booster damaging it? Or should I push the rod down to the stock hole for power brakes, but I'm worried that will bind the rod?
Specs: 67 Camaro, stock pedal, Tuff Stuff 9" dual diaphragm vac booster part #2224NC, DSE reduced angle brackets, master cylinder 18M974, Kore 3 Z51 disc brakes.
I'm hoping someone here has a similar combination of parts and can tell me what worked for them.
