    Results 1 to 7 of 7
      Sep 2009
      Atlanta,Ga.
      Late model steering column?
      Will a 2006 GTO steering column or any other late model column work in a 1970 Cutlass? I plan on changing out the Steering box to a Jeep one or so also.
      I am SUCH a rookie to Pro-Touring
      Feb 2007
      Tinley Park, IL
      While almost anything can be made to work, the column from a late model GTO won't bolt in by any means. If you're going through the trouble to modify a late model column to fit, I'd also suggest a better upgrade than a Jeep steering box.
      Nick ~
      1969 Cutlass
      Sep 2009
      Atlanta,Ga.
      Quote Originally Posted by Mr Nick View Post
      Is Lee steering boxes back up for sale? I will look into some better alternatives.
      Oct 2010
      Sacramento, CA
      You can probably use a 3rd or 4th gen camaro column. They still used a round column vs the newer rectangular plastic versions. I installed a modified 1989 column with a 2002 wiper controller in my 1969 camaro.
      You will have to change out the firewall mount and I used my original dash mount bracket after grinding a relief for the high beam activation rod.
      Rick
      Rick - 1969 Camaro - LS1 driven daily
      Feb 2007
      Tinley Park, IL
      Nick ~
      1969 Cutlass
      Jacksonville, FL
      I think Lee is back in business.
      http://www.steertechgrp.com
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Sep 2009
      Atlanta,Ga.
      Quote Originally Posted by ccmc View Post
      Rick
      I will be looking into that. Thanks
