1968NovaMD
09-05-2016, 04:18 PM
Clean, straight Nova looking for a new home. Looking to get $18,500.
Pics: https://drive.google.com/drive/folders/0ByCuZVsWC94YMEtobTNKSWNqMUk
Video: https://www.youtube.com/watch?v=o05E9kC6qGw
Cliff Notes: RideTech Front Suspension, Unisteer Rack & Pinion, Hydro-Boost Brake System, Wilwood Front Brakes, New Hard Brake Lines (Front/Back), Comp Engineering SubFrame Connectors (Not Installed), Detroit Speed MiniTub Kit (Not installed)
Engine
The previous owner knew little to nothing about the engine other than it was a period correct (1968) block, but was not original, and that it at least had a cam and heads installed. It runs perfect, and sounds amazing.
Edelbrock Performer Heads
Long Tube Headers
Dynomax Bullet Mufflers that end in turndowns near the rear wheels
MSD Billet Distributor (New)
MSD 6AL Box
Transmission
Muncie M20 4 Speed
Hurst Shifter
Ram Clutch
Rear Differential
Ford 9” Rear Housing (was told it was from a 1970’s LTD)
Richmond 4.11 gears w/Full Spool
Body
Body is extremely straight, no dings or dents that I have been able to find. Underside of the body is all rust proofed and painted black. Frame is painted as well, and in fantastic shape.
Paint
Paint is in pretty great shape. When I first bought the car, I didn’t notice any defects or chips. After its first wash/wax/detail session I noticed a few ‘chips’ on the front fender and rear quarter panel. All in all, less than 6 imperfections that I can find. It’s a solid paint job, you have to be almost right next to it to see most of these chips.
Suspension
New Factory SubFrame – Painted Satin Black and welded top and bottom
Ridetech RQ Series Coilovers - http://www.ridetech.com/store/1968-1974-nova-coilover-front-system-non-adjustable.html
Ridetech StrongArms Lower Control Arms - http://www.ridetech.com/store/1968-1974-chevy-nova-strongarms-front-lower.html
Ridetech StrongArms Upper Control Arms - http://www.ridetech.com/store/1968-1974-chevy-nova-strongarms-front-upper.html
Ridetech 2” Lowered Spindles = http://www.ridetech.com/store/ridetech-spindles-pair.html
Ridetech Musclebar (swaybar) - http://www.ridetech.com/store/1968-1974-chevy-nova-musclebar-front.html
Competition Engineering SubFrame Connectors (Not installed)
Detroit Speed Mini-Tub Kit (Not Installed) - https://www.detroitspeed.com/1968-1974-X-Body-products/041207-mini-tub-kits.html
Steering
Unisteer Rack and Pinion Kit
2 Knuckle Steering Shaft
Flaming River Black Steering Tilt Column
Brakes
Bosch Hydro-Boost Unit
New Master Cylinder
Wilwood 12” Rotors in Front, 4 Piston Calipers
New Hard Brake Lines Front/Rear
New steel Braided Front Brake Lines
Stock Replacement Manual Drums on Rear
Rear drums just replaced last year by previous owner
Wheels
Weld 5 Star Racing Wheels - http://www.jegs.com/p/Weld-Racing/Weld-Racing-Pro-Star-96-Series-Wheel/746350/10002/-1
4” Wheel up front
8” Wheel in Back
Interior
In very good shape, all door panels, headliner, rear seats and trim are in great shape.
Fixed back racing bucket seats
New Carpet
Misc.
New Fuel Tank
New Fuel Sender
New AED 750 Carb
4” Cowl Hood
New Optima Red Top Battery
https://static1.pt-content.com/images/pt/2016/09/20160826_175546-1.jpg
https://static1.pt-content.com/images/pt/2016/09/20160826_175527-1.jpg
Engine
Long Tube Headers
MSD 6AL Box
Transmission
Muncie M20 4 Speed
Hurst Shifter
Ram Clutch
Rear Differential
Body
Paint
Suspension
Steering
Brakes
New Master Cylinder
Wheels
4” Wheel up front
8” Wheel in Back
Interior
New Carpet
Misc.
New Fuel Tank
New Fuel Sender
New AED 750 Carb
4” Cowl Hood
