View Full Version : Weld through primer
65 drop top
08-22-2016, 03:06 PM
I removed the spare tire well on my '55 Chevy and am about to plug weld in a flat panel. I want to protect between the flange and panel from rust. I started to spray it with a galvanized weld through primer and started thinking if that is the right move or not. Is the galvanized weld through primer best for corrosion resistance? When plug welding, can you actually weld directly to the primer or do I need to hit bare metal? Using a mig if that makes any difference.
dhutton
08-22-2016, 03:16 PM
I have had good luck with 3M weld thru primer. It allows welding without removing it to bare metal. Some guys use epoxy but as near as I can tell it just burns up and you have to remove it to weld.
Don
Wall
08-22-2016, 04:24 PM
I have used the SEM weld thru primer and a few others that worked but were really a pain to weld with. Even if you did clean the primer off just at the plug weld hole it still splattered and sounded like bacon frying.
The brand that I have heard works really well is Medallion RS 512. http://www.medallionrefinish.com/Editor/assets/tds/rs-512_tech.pdf
I haven't tried it yet but plan to next time I have to use weld thru primer.
blu72nova
08-22-2016, 04:35 PM
I've used zinc and copper based weld through primer. I've had better luck with the copper as far as ease of welding. In either case, you can tell you are not welding to bare metal. Remember it's still important to seam seal even with weld through primer. Here is what i use.
https://www.amazon.com/SEM-40783-Copperweld-Weld-Thru-Primer/dp/B003TQGT4S
MuscleRodz
08-22-2016, 06:37 PM
I have used them all and prefer upol over 3m and sem
mikey
09-21-2016, 08:54 AM
Upol is the way to go��
Buryingthesun
09-21-2016, 09:26 AM
I use SEM copper weld. I always mask the areas I'm welding, surface blast to remove paint or impurities. Then while its still masked I spray the SEM copper weld on.
badazz81z28
11-03-2017, 04:34 PM
Do you have a part # for the Upol?
