Juzzy
08-13-2016, 10:20 PM
Hey all
I know this question goes around alot and I've been researching this and it's starting to do my head in. As I'm trying to get info in Australia, there aren't any Wilwood reps here or enough people who have done the conversion. (when I say 'enough' not as much as the US).
I am running a wilwood 1"bore master cylinder, 12.19" rotors with Wilwood 4 piston Dynapro Dust Boot callipers all round. (http://www.wilwood.com/Search/PartNoSearch.aspx?q=120-11481)
I want to know whether this manual setup, will give me a good responsive feel, that I could lock the front wheels (or close too) if I so intended. If not, how should I boost it if running a stock ZZ502 with average vacuum. If it doesn't come close to my Subaru, then I will ditch the master cylinder for a hydraboost setup as I fear the 1" bore the hyraullic assist may put me through the windscreen. I don't like them 'grabby' brakes. I want a good feel - the more pressure, the more you stop, without cramping your leg.
Any help on this would be much appreciated.
Cheers!
Cheers!
