    Results 1 to 7 of 7
      Grand Rapids, Michigan
      4 Wheel Disk's for '67 Chevelle
      Anyone have any recomendations, or know of any kits. Don't need racing caliber stuff, just an improvement over stock.
      Thanks, Kurt
      May 2002
      Northern California
      depending on the rims your going to run you can do a C5 front, LT1 rear disc. An ATS front spindle should be on your list of modifications. I got lucky and did my set up for under $700. You can get cheaper than that I hear.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Marshall , MO
      Here is a list of several options. For the rear LS1 or LT1 f-body rear will work. http://www.chevelles.com/forums/showthread.php?t=107745
      Quote Originally Posted by MrQuick
      17 X 8 fronts, 17 x 10 Rears
      Will those work?
      Are there kits available? or did you just gather some used parts?
      These Disk brake conversions with C5 fronts and LT1 rears, are they kits or do I piece together used parts?
      May 2002
      Northern California
      depends on how you want to go about it. You might save some money if you piece it together. I would go with new or rebuilt parts.
      Price the full kits out and maybe we can beat it.
      ...let me know if you need some brackets, I can help with part numbers too.
      what type of rims? Im running C5's 13" rotor with 17's and a 1/4" spacer with TTII's
      Boyd Coddington Smoothie II's
