View Full Version : Off Road, LS Engine, Too Many Parts!
jwcarguy
06-11-2016, 08:59 AM
Clearing out shop after move and various car builds
Some members may be into multiple motorsports like I am and will know the offroad parts as well
Prices do NOT include shipping from Las Vegas, NV 89131
Will post all pics soon (alot of them!), or pm/ text for pics
Off Road Parts:
-Cables:
- 1 pair of #4 push/ pull control shifter cables used, 2" throw/ travel, 55" overall, 42.5" bulkhead to bulkhead centers $80 pair
- 1 #4 push/ pull control shifter cable , new, 1" throw/ travel, 79" overall, 69.5" bulkhead to bulkhead centers, from Kartek $60
- 1 #3 push / pull throttle cable , new 3" throw/ travel, 140" overall, 126.5" clip to clip, from Kartek $40
- 1 #3 push/ pull throttle cable, new, 3" throw/ travel, 156" overall, 142.5" clip to clip, from Kartek $40
- 1 PBS/ Mendeola S4 shifter, new, from PBS $60 SOLD!
- 1 pair of CNC Turning/ Steering brake handle knobs Blue, new (just mock up, changed color) $20pr.
- 1 Tilton oil / gear cooler pump w/ wiring, relay, used, cracked fan cover (#40-910 $12 to replace) $125 SOLD!
- 1 Allstar Performance billet oil filter / ?? mount , new (#92046) $20
- 1 Tru-Cool/ LONG oil cooler with #10 an stainless braided hoses and fittings, used, (cooler is 11 x 11 x 1.5", hoses are 34" w/ 90 degree fittings, 38" w/ 45 degree fittings $75 SOLD!
- 1 Aeromotive billet fuel filter mount, new $50
Hoses & Fragola Fittings:
- 1 #8 power steering hose, new, 53.5" overall w/ fittings installed (1-90, 1-straight) $30
- 1 #10 power steering hose, used, 39.25" overall w/ fittings installed, (2-45 degree ends, clocked close to opposite each other) $30
- 1 #8 x 120 degree Push Lock black (2125008-BL not in bag) $15
- 1 #8 x 90 degree push lock black (#209008-BL) $15 ea
- 1 #8 nut x #6 male swivel reducer black (#497208-BL) $6
- 2 #8 female connectors black (#496108-BL) $6 ea
Drivetrain:
- 1 pair of Pro Am 934 Double Boot flanges (trans side w/ 1/2" holes)w/ outter boots & o-rings, need inner boots, mocked up $100 pair SOLD!!
- 1 934 33 spline 300m axle, low use, 34.5" overall, (one end trimmed down 3" spline & 4" spline lengths) $300
Springs/ parts:
- 1 pair of King coil springs for 2.0" c/o shocks (#2.5-12.00-400) new $100pr
- 1 pair of King coil springs for 2.0" c/o shocks (#2.5-12.00-500) used half season $60pr
- 1 pair of King lower spring retaining plates (flat) for 2.0" c/o shocks new $40pr
Rod ends & threaded bungs;
- 2 5/8"-18 Hex RH bungs for 1" tube, (don't recall for which tube size, bung is .748" od @ tube insert end) new $15pr SOLD!
- 2 5/8"-18 Smooth RH bungs for 1" tube (don't recall for which tube size, bung is .807 od @tube insert end) new $15pr SOLD!
- 4 5/8"-18 RH & LH (2 of ea) Chromoly rod ends w/ 1/2" hole $20 ea SOLD!!
- 4 1/2"-20 RH & LH (2 of ea) Chromoly rod ends w/ 1/2" hole w/ smooth end threaded bungs for .065" wall 1" tube and jam nuts $30 ea SOLD!!
LS / Vortec engine parts:
- 1 SPEC steel flywheel, light use $150
- 1 pair of RSI Billet Fuel Rails, black (bought for stock LS3 manifold, but not correct size) (see pics for dims) with new fittings also, used SS crossover I had $140 SOLD!
- 1 BTR (Brian Tooley Racing Stage 4 n/a cam (233/250, 619/595 113+5 LSA , 3 bolt) used 2500 miles $300
- 1 Comp Cams cam w/ XE-R lobes (224/236, 581/602 113 LSA ,3 bolt) used low miles $300
- 1 GM stock LS3 cam (#3063 ,single bolt) low mileage take out $50
- 1 GM stock LS2/ LS3/ LS7 fuel rail (#12638197, new take off) $80
- 1 3 bolt throttle body to 4 bolt throttle body billet adapter w/ o-ring, used $40 SOLD!!
- 1 set of MSD spark plug wires for LS1/2/3/6/7 , low use $30 SOLD!
- 1 set of GM stock take off LS3 spark plug wires , low miles $20 SOLD!!
- 1 GM LS3 LS7 card style MAF Sensor with 4" dia alum tube and welded bung, tube length is 4", used $120
- 1 Stainless steel 4" dia " Y air intake tube", has slight bend ,(see pic) 14" overall, 5 1/2" tall, used $80 SOLD!!
- variety of lengths of 4" dia. aluminum intake tubing & rubber couplers (2@ 5 1/2", 2@ 4 7/8", 1 2 5/8" w/ 9/16" hole, 1@ 12") couplers are 2 3/4" & 3", used, Offers ? SOLD!!
- 1 Throttle cable adapter (Morse style cable to cable throttle body DBC) 10 1/4" long, used $10 SOLD!
- 1 pair of GM LS3 rocker stands ( 1 pair used) #12600936 $10 -used pr
- 1 pair of GM LS1/ Vortec rocker stands, used $10
- 1 GM "LS6" oil pump,(#12556436) new, bolted to engine, then removed, never run $70
- 1 GM Gen III knock sensor harness, used, $15
- multiple sets of 5 GM/ aftermarket LS1 / LS6 Fuel Rail Cover mounting studs $50/ set of 5
- 1 set of 16 Texas Speed #25-7450 7.450" .080 wall Pushrod set, new in box $90
Other:
- 1 pair of Rigid Industries Dually LED lights, Amber & flood pattern, new, but mocked up and chassis sat out in sun, black is faded a bit w/ connectors/ plugs $100 SOLD!
- 2 SPAL 14" Electric fans, curved blade, new, but mocked up and chassis sat out in sun, fan "grilles" have a few missing ribs, never used $75 ea SOLD!
- 1 pair of weld in seat mounting brackets, 18" center to center spacing, new $40pr SOLD!
please pm/ call/ text (702)677-4085
[COLOR=#000000]Thanks, Jeff[/COLOR
jwcarguy
06-11-2016, 09:02 AM
additional pics
badazz81z28
06-11-2016, 11:43 AM
Jeff why wouldn't the billet rails work on the ls3?
jwcarguy
06-11-2016, 12:10 PM
The front to rear spacing was correct, but not the side to side (with the mounting brackets that I got with them) needed to be "pushed out" from intake manifold
I will post pics on the dimensions
jwcarguy
06-16-2016, 06:15 AM
list updated
jwcarguy
06-24-2016, 08:20 AM
weekend bump
jwcarguy
07-02-2016, 08:10 PM
Holiday bump!
jwcarguy
07-11-2016, 06:21 AM
List updated
jwcarguy
07-24-2016, 09:59 AM
updated list
