View Full Version : Which lug nuts for Forgelines?
badazz81z28
03-12-2016, 09:48 PM
Looking for some black lug nuts for Forgelines. I see many on eBay, but not sure if the quality and strength are any good.
Schwartz Performance
03-13-2016, 05:38 AM
Gorilla spline drive black ones are available on summit
-Dale
badazz81z28
03-13-2016, 07:50 AM
Thanks Dale, I noticed they don't have open lug nuts in that style, do you cut long arp studs or use a different style?
HandOverFist
03-13-2016, 08:12 AM
http://www.ebay.com/itm/VMS-20-PIECE-RACE-LIGHT-WEIGHT-WHEEL-RACING-LUG-NUTS-7-16-20-BLACK-OPEN-END-/310673310512?hash=item4855928330:g:4PIAAOxyMZ5Rmmo Z&vxp=mtr
badazz81z28
03-13-2016, 10:06 AM
Thanks, I feel maybe I should stick with steel. Plan on putting drag slicks on my car every now and then
03-13-2016, 01:21 PM
We cut the long studs down. You could also cut the ends off of the lug nuts if you really want or need them open.
Also it sounds weird but one of my friends plastidipped my daily driver wheels dark grey and did the lug nuts as well.. I've been surprised that they haven't peeled yet, been about 8 months, and through the winter so far.
Might be an option to try..
-Dale
cspecken
03-14-2016, 11:21 AM
I just picked up a set of McGard Spline drive lug nuts. The appear to be good quality. It does take a special tool to use them.
dontlifttoshift
03-14-2016, 11:49 AM
I loath spline drive lug nuts. They shouldn't exist.
I do like these.
https://static1.pt-content.com/images/pt/2016/03/gor45038bc20_xljpgrepFalse-1.jpg?rep=false
sccacuda
03-14-2016, 12:27 PM
I do like these.
Splines do suck! Looked up the Gorilla "race" lug nuts. I guess as long as your only racing with 1/2" studs you can use these. I couldn't find anything in 5/8". I do like them, just need to be bigger!
badazz81z28
03-14-2016, 01:04 PM
Thanks Gents, My only concern really is fitting in the Forge line wheels holes. Right now my China wheels barely allow the socket to fit inside and it has cause it to get marred up.
TheJDMan
03-14-2016, 02:31 PM
I hadn't seen those Gorilla nuts before. I like the knurl on the end. That would solve a problem I have with my current nuts being awkward to start with my Forgelines.
dontlifttoshift
03-14-2016, 02:40 PM
^^^^Exactly why I like them.....and part of me likes that they stick out because racecar....
RE: socket clearance. Any thin wall 3/4" socket should fit in just about any decent wheel (there are rare occasions where the splined lug nuts are required) so just make sure the lug nuts you purchase have a 3/4 hex.
BADNBLK
03-15-2016, 08:02 AM
I just ordered up a set of the Gorilla splined drive lugs, as I had little to no other option. My moser axles have 7/16 studs in the rear and this was it haha!
Can't wait to bolt on some Forgelines!
Ron Sutton
03-15-2016, 12:28 PM
You know ... that I know ... where to get the 5/8" lug nuts. Only once source. LOL
:secret:
TheJDMan
03-15-2016, 03:42 PM
I would redrill the axles for 1/2" studs.
BADNBLK
03-16-2016, 02:57 PM
I just have front lugnuts and rear lugnuts now haha. Luckily Gorilla uses the same size spline externally, so I won't have to have two thinwall sockets anymore.
icemanrd19
08-28-2016, 06:59 PM
funny that I've spent about a hr researching lugnuts.
Cant decide between open ended or closed. i will go with nickel plated or chrome.
r67nova
08-31-2016, 10:38 AM
Do you have any picks of them on the car?
