View Full Version : Custom lenses?
verticalflight
02-14-2016, 10:35 AM
Cross point to make sure the fabrication guys see this post... (scroll to bottom of page for latest update)
https://www.pro-touring.com/threads/119134-Your-input-on-how-to-fabricate-these-parts-is-by-hand-possible?p=1175382#post1175382
Best,
Kris
blown32
02-14-2016, 04:01 PM
123942123943
This is what I did with my all steel 32 ford coupe, we made a custom metal box and inserted into the body. Made a wood plug made out of oak and shaped it to the contour of the body leaving a 1/8 gap top and bottom in order for the lens to be pulled over the wood buck. I then took it to a sign shop in Phoenix picked out a color of lens that I liked. They then heated the lens to form over the buck. I had to buy a full 4 X 8 sheet of plastic which made a total of three taillights. Broke the first one trimming the corners. Second ones in the coupe and still have a back up. I would say visit your local Commercial Sign shop.
jlcustomz
02-18-2016, 06:15 PM
What blown 32 just posted is pretty much what I first described about forming your own lens, plus the sign shop tip. Won't give you an inner texture, but that's pretty much the average way to bend sheet plastic.
Plastic heated to the correct temp range will be soft enough to bend & conform, but not flow out all over the place
53Vipette
05-08-2016, 07:22 AM
Best,
Kris
For the inner pattern why not make a paint mask and spray Kandy or tinted clear to make it look patterned? The light will vary between painted and unpainted areas.
