    Results 1 to 4 of 4
      Feb 2011
      dallas, tx
      AC compressor 90 degree fittings with service ports
      I have my vintage air ac compressor on its side. I want to use two 90 degree angle fittings coming off of the compressor. The 90 that vintage air has would have the port facing towards the passanger fender. For the top hose thats fine. The problem is the bottom hose the service port would hit the fender. Does anyone make 90 degree ac fittings that the service port would be facing up?
      If you were holding the fitting in your hand with the screw on facing away the service port would be on your right hand side.
