    Results 1 to 17 of 17
      Portland,Oregon
      what don't they make for a 1969 Camaro
      Just tor my car down to a bare shell and I want to toss some stuff.
      I'm just wondering what doesn't the reproduction places make?
      What part can we not get for our cars?
      Robert Braga
      1969 Camaro LS2/T56 D1SC
      www.automotivedesigneng.com
      US Collision / Mortenson's Custom Touch / DPE Wheel / Tim Bruning / Columbia Parts Company
      Las Vegas, NV
      Be careful when "tossing some stuff"!! There are alot of people out there that want the original parts. You could post an ad here and on Team Camaro to sell off the parts to help fund your current project!! I've done this for a long time! Let me know what you may have , I have a few people with 69's. Hope this helps, Jeff
      Jul 2003
      Anaheim Hills, CA
      They DON'T make the wiper transmission arm.. I had to find a brand new one (OEM) and it only cost me $250..
      1968 Track Rat Camaro:
      Portland,Oregon
      Quote Originally Posted by Steve1969LS1
      Whoa, I almost tossed that.
      okay what else don't they make?
      Sad thing is I already threw alot of stuff out.
      Robert Braga
      Burnaby, BC, Canada
      The metal trim on the inside of the windows for the headliner, and the upper door opening stainless molding that the weatherstrip fits into. Also keep all your brake line clips and brackets. Also there are tons of nuts and bolts that are hard to find, so don't toss any of those. I think seat springs/frames are also not made new. Just some stuff I that I can remember.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      May 2002
      Northern California
      Referbishing what you already have is a good way to keep a project build cost down. You would be surprised what a bead blast and a coat of paint can do to a part. You might want to keep everything and toss out after the build. If your short on space the set up a triage and then put together a list for someone to go over...toss out the obviously damaged or unsavable ie: rust damage.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mar 2003
      Kirkland, WA
      I'll second that, don't toss anything until the project is done. Sometimes just having the reference is an advantage.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Nov 2004
      Colorado
      Given the sorry quality of most repro stuff, I'd hang onto everything.
      The dash pad does not fit right, the urethane pillar moldings look like cr@p, the chrome bits are pitted.
      I could kick myself for tossing the dash pad that came in my car, it was a bit warped, but one just like it went for a couple hun on ebay.
      Indianapolis, Indiana
      What they don't make
      Contrary to what they told you above you can now buy the wiper transmission. Also the weatherstrip retainers are also listed but I am not 100% sure that they are avalible. Two things that I know that aren't avalible are the metal drip rails that weld under the roof skin and the inner rocker supports (if you have a coupe). Also torque boxes aren't avalible unless you buy the full floor. The main thing is to look how far we have come. By the end of next year you should be able to buy a new coupe body (from what I have read on other forums and websites).
      Ben Mowery
      67 Firebird -Powered by Pontiac w/ RAM AIR V.
      Miami, Florida
      They don't make all the weird little rollers and clips that are in, on and through the window glass. I don't know if they are called guides, rollers, tracks, or whatever. Make sure that you keep all the stuff from the insides of the doors and the window glass hardware.
      I think you better keep as many of the clips, clamps, etc that hold and route the old harness as possible, keep the harness as well. Many of the clips and stuff aren't reproduced. Alot of the under dash bits and pieces as well.
      Kevin.
      69 Firebird "Eternity"
      Maysville, KY
      Well lets think. The rear seat devider, the front frame (Stock frame), the roller for windows, the section between the rear floor and trunk, The inner areas of the rear window sheet metal, they offer sheet metal shock towers however they have to be cut and reinforced, exact replica am/fm radios. Keep everything that you possibly can and don't worry about fitment.
      Kevin Turner
      Maysville, KY
      3-69 Camaro's
      02 S10 extended cab that's street legal & runs 10's on motor and 9's with spray.
      04 GMC Denali Quadsteer truck black with black 22's.
      04 GTO LS1 that loves to be sprayed and meet imports on the street.
      England
      Do not sell until you have finnished the car as, you will always need what you have let go.
      paul67
      St George Utah
      we have just torn one appart and there will be alot of parts that won't get reused. likt the wiper transmissions brake/ fuel line brackets factory console, steering column heater, seats, dash cluster,if any one is interested send me a list of what you are looking for and i will let you know if it is available
      Jun 2005
      Bellmawr, New Jersey
      Be very careful tossing things. Some terminals are needed from the old electrical system for example. If its a true restoration, when you get to the electrical part - call us. We'll let you know what you can still use or what you may need to get new. You can always call toll free 800-482-WIRE. Ask for ext 16, Don Bock - our Tech Guy. Or, of course, feel free to send me an email and I'll get you the answers you need.
      [email protected]
      Theresa
      Portland,Oregon
      wiring harness was the first thing in the trash.
      So many wires were cut and spliced and burnt up. I didn't even want to think about putting any of it back.
      Robert Braga
      Apr 2003
      chbg, pa
      Dude , you have no business building a car with a question like this . You dont throw any thing away untill the car is done . Trust me you will regret it .
      Mar 2002
      Redwood City, CA
      Quote Originally Posted by 96Z28SS
      Trust me, it can still be of use. As you will be rewiring the car, you can still use that trashed piece as a reference. Not only that, but you can also learn from it. Oh, and don't throw any part away until AFTER you have the replacement for it. That one is from experience.
      Allen Ortega
