    Results 1 to 12 of 12
      Aug 2015
      Michigan
      KDW2 discontinued... HELP.. What tire should I go with now?
      My forgeline wheels will be delivered tomorrow and the KDW2's have been discontinued???
      what tire should I go with now? What are you guys running?
      Looking for 295-35-18 and 255-35-18
      Any help will be appreciated,
      Richard
      Feb 2011
      dallas, tx
      which size is discontinued? both? what kind of car and wheel size?
      Aug 2015
      Michigan
      Quote Originally Posted by icemanrd19 View Post
      I have a 1987 Buick Grand National.
      I have Baer big brake kits all the way around
      im also running ride tech level II tru turn coil over set up.
      Both sizes are discontinued.
      The KDW2's are discontinued.
      looking for suggentions on what i should get instead.
      Thanks, Richard.
      Windsor, CO
      BFG Rivals...?
      Brandon Pursley,
      Aug 2015
      Michigan
      Quote Originally Posted by BADNBLK View Post
      BFG Rivals...?
      are the rivals any good?
      Are they the replacement for the KDW2's??
      May 2012
      Quote Originally Posted by CanMove View Post
      Way better then the KDW2s
      Tab at top of pages tells all about them
      Aug 2015
      Michigan
      Quote Originally Posted by Vegas 69 View Post
      There is no 255/35-18
      only have the 295/35-18 i need??
      Aug 2015
      Michigan
      Thank You!
      I think i got it figured out now. Rivals. Just have to nail down the exact sizes.
      Apr 2012
      Woodstock, IL
      Sport Comp II is another option, might have your sizes
      -Dale
      SchwartzPerformance
      Jun 2010
      Deployed
      Richard, before you buy tires...do you need 200 tread wear tires? Keep intended use in mind. It would suck to wear those tires down quick unecessarily. I run BFG g-force tires for all around summer performance. I think the tread wear is 340 of so.
      1970 Camaro/DSE build
      Oct 2005
      Bay Area CA
      Be thankful the KDWs were discontinued. They were terrible tires. The best street tire currently available is the Michelin pilot sport super sport. Not an R compound but definitely the best street and mild track tire you can get.
      1968 Restomod FireBird • Twin Borg Warner EFR Turbocharged LS3 • T56 Magnum • Ford 9”• Modern Sub-Frame & Suspension • C7 Seats • 24 Pistons • Forgelines
      Jan 2011
      Boston, MA
      Have you looked at Nitto NT05's? You can get them in a 295/35/18 & 255/35/18
