    Results 1 to 7 of 7
      Apr 2015
      Gas tank with cut corners for wide tire clearance- 2nd gen fbody
      I know there are clearanced tanks made by ricks and I think DSE. However, these all require electric fuel pumps. Someone on here I thought made them from stock tanks and they looked darn good. The corners were just cut, welded nicely, and it even looked like the tank was regalvanized. I can not find the original post where a picture was posted. Can someone direct me to the guys who make these clearanced tanks? They were like $150 if I remember right. I know for SURE they were under $300. Much cheaper than a rick's stainless tank. Any help- links or contact info- would be greatly appreciated.
      Apr 2012
      Woodstock, IL
      Tanks Inc?
      -Dale
      SchwartzPerformance
      Apr 2015
      it does not look like they offer a notched corner version for a 77 TA. Their tanks also appear to be for fuel injection only. I just put a new large mechanical pump and pick up on from robb mc a couple years ago and would like to keep that setup. Does anyone else offer a notched tank or am I going to have to do some cutting and welding?
      Jun 2010
      Deployed
      Can't be too hard to do it to a stock replacement tank. If you can weld.
      1970 Camaro/DSE build
      Apr 2012
      Woodstock, IL
      They offer it for non EFI too, but yeah I guess the notched part is your issue.
      Sorry, not sure of anyone else that does stock style tanks for 2nd gens
      SchwartzPerformance
      May 2015
      Island Lake, IL
      Schroeder, you can use a carb fuel pressure regulator with an electric pump ;)
      Are you running a setup that's not leaf spring?
      Apr 2015
      I just bought all the new mechanical stuff and it seems to work, so I don't wanna replace it already.
      I'm running a quadralink from dse with fat rear tires
