View Full Version : How long to install level 2 non air Ridetech
keith4909
11-22-2015, 04:17 PM
Any a body gm muscle car
64-72
I just swapped out my 10 bolt for a 12 bolt and it took about 2 hr with bleeding and no lift. I'm pretty quick and have a good back ground in auto repair. Just want an idea so I know how much time to set aside. I would be doing it solo. Car has 4 wheel disc of that matters.
Josh@Ridetech
11-24-2015, 01:36 PM
The A body kit is pretty simple to install, no welding, no cutting, just bolt on parts. If you're doing the level 2 coilover kit, bolting the pieces on will take you a few hours. Getting it set at ride height, fine tuning the shock valving for your liking, and getting the alignment set are the only parts that will require any more time. You could have it done in a day, pretty easily.
keith4909
11-27-2015, 07:50 PM
Wonderful. That's what I was thinking too. Thank you for the quick response.
Josh@Ridetech
12-03-2015, 01:27 PM
No problem, let me know if you need anything! :twothumbs
