    Results 1 to 20 of 21
      Sep 2013
      Country Flag: Finland
      1967 camaro and 120x5 wheels
      I´m thinking of bying these wheels for my camaro 120x5x17x8,5 and the et number is 20? What does the 20 mean? Will those fit in the original wheels housing, my car is lowered about 2" and do i need less et in the front? These are bmw wheels i think. i can get the front ones also with et number 15. oh and the wheel is lemans gold.
      Apr 2007
      The bolt pattern is off by enough that you will never get the wheel to run true, and more importantly you are forcing the wheel stud to bend like a palm tree in a hurricane. Don't do it!
      Sep 2013
      Quote Originally Posted by iadr View Post
      theres many who have done this and said that theres no shaking etc at all and wheels fit like original one. only one millimeter difference per side comapred to original wheels.
      Apr 2007
      congrates on learning English. Now learn some facts.
      Atlanta GA
      damn iadr.. sound kindof dickish man... chill.
      I have run 3 sets of bmw wheels throughout my cars builds... not one problem.. autocrossed in em, drove home in em, went to get iced coffee and everything..
      Stormy on some rare ass OZ mitos(which I WISH I didnt sell...)
      dicking around on road Atlanta..
      when it was on Mparallels...
      and no problem with either..
      so yea.. man.. there is a very small difference and its not the best but you can ride on it without issue as long as you dont wild out.
      Sep 2012
      its 1 millimeter across 5 studs. like .0065
      theres more play in any wheel anywhere.
      Mar 2015
      Mr. Vengeance, What wheels are in the last picture? Good Lord they are nice!
      Atlanta GA
      M Parallel wheels..
      they look great and kindof a Kinesis look to them for a fraction of a price..
      heres some other ones I know of with the MParallels..
      Mar 2014
      Long Beach
      Et means offset
      google image backspace vs offset(et) and use one of the charts to figure out what your current wheel offset(et) is
      The best online wheel calculator I know of is willtheyfit.com
      You put in your current wheel and tire specs and the new wheel and tire specs and it overlays them both on top of each other and tells you the inner/outer and diameter differences
      As far as the 5x120 debate is concerned you could get some arp wheel studs for peace of mind. $60 for a set is cheap insurance.
      Dec 2010
      Fredericksburg, VA.
      Technically, a 120x5 bolt pattern wheel should not be used on a 4.75" x 5 hub. In reality, they are so close that I have never heard of anyone who has had a problem doing it. Just tighten the lugs in a star pattern in small torque increments.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Sep 2013
      Thanks you all for the info! Theres ton of good wheels to buy :D
      Sep 2015
      Rockvale TN
      Would it be possible or advised to relieve the wheel holes equally in order to take the bind out?
      Feb 2006
      Idaho Falls, Id
      For those concerned with the difference in lug pattern, here's a fix
      http://www.thirdgen.org/forums/wheel...t-pattern.html
      That cutter is like $60.
      If you are ever running 5x120 wheels and need a spacer anyway, you can get 5x4.75 to 5x120 adapters.
      Traven
      Sep 2015
      Rockvale TN
      Would it not be possible to have the axle flanges/rotors drilled with an extra set of holes in the 5x120 pattern?
      Feb 2010
      It is possible..... But why bother with it when 5x120 will work fine?
      I am running 5x120 xxr's and they work fine as is, plenty of other people run 5x120 as well without issues. In fact I don't know of anyone who has had an issue. My 5x120 wheels actually seem to fit better than the boss 338's that were 5x4.75. Here is a pic for reference.
      Feb 2006
      Tennessee
      Quote Originally Posted by HandOverFist View Post
      This is possible, and is exactly what I did to run my BBS wheels. In my case, my build required new axles, hubs, rotors, etc anyway so it wasn't a big deal to incorporate the extra bolt spacing for 5x120.
      Kerry
      66 Chevelle - LS-Leap
      LQ9 / T56 Complete - Phase 2 in process!!
      https://www.pro-touring.com/threads/...t-LS-Heap-quot
      SC&C, Kore3, Detroit Speed, BBS, Advanced Induction, TickPerf, Currie, Moser, Holley, Hellwig, Edelbrock LS-Kit, Mast, Wilwood, BP-Automotive, StopTech, Ridetech, Hotchkis, UMI, Energy Suspension, AAW, B&B Classic's, PPG, Aeromotive, Canton, C&R, Sparco, Ididit, Spectre, Bridgestone, DakotaDigital, Alpine, RockfordFosgate
      Atlanta GA
      Quote Originally Posted by the owl View Post
      that looks great!.. are those 19s?
      I will say this that the BMW wheels I had put on the Camaro had to have the center hub clearanced
      Feb 2010
      Thanks man, greatly appreciated especially coming from you as your cars always had great stance!
      They are 20x11 in the back and 18x9.5 up front.
      Sep 2015
      Rockvale TN
      Quote Originally Posted by analyte View Post
      Kerry
      Who did you get your axles from? I emailed Moser to inquire if they would build me a dual pattern set (5x4.75 and 5x120mm).
      Sep 2015
      Rockvale TN
      What should I be looking for in 5x120mm in regards to offset? For a '67 El Camino, how would something like this relate? http://www.ebay.com/itm/181798686864...%3AMEBIDX%3AIT
