    Results 1 to 4 of 4
      Sep 2007
      68 Camaro..anyone know if 15" wheels will fit over the 4th gen brakes for drag pass??
      Hey guys,
      Have a pro-touring 68 with a built small block..wanting to go do a few more passes at the strip with some hoosier quick time pros or the like to see if I can hook up better than a 2.1xx 60 ft times.
      2 questions...on stock wheel wells/suspension type..
      Will 15 inch wheels fit over the 11 or 12 inch 4th generation F body rear brake setup?
      And what is the biggest "drag type" tire I can run on the rear for drag racing?
      Running 275 / 40/17 Nitto 555R's now so they're 26.5 inches tall roughly by 10.2 inches wide.
      Thanks for any advice or combos that might have worked?
      Donnie
      Aug 2001
      Connecticut
      You should be ok on the brake clearance, my setup in the 90's was c4 brakes front and rear with 15" rally rims. I think that was 12" front and 11.5" rear, the camaro and vette rear calipers were the same except the ebrake pull direction.
      A few years back I tried some m&h drag radials 275/40/17 or 275/50/17 I forget and they just fit but I did have to raise up the back with the coilovers, it was a 28" tall tire, still got them now that I thinking of it, one more thing to get listed for sale.
      1968 Camaro RS/SS, LS7 with Katech mods, T56 Magnum, C6Z06 Brakes
      1968 Camaro RS Convertible LS3/480hp/4L70E
      1962 Corvette 327-340hp stock
      1963 Corvette Split Window Coupe
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Oct 2007
      Georgetown/Austin, TX
      Lots of guys with 4th Gen Camaros run 15's. Check out this thread for a ton of good options. --> http://ls1tech.com/forums/wheels-tir...-calipers.html
      Sep 2007
      Thank you guys so much for the replies!!
