408maro
10-10-2015, 08:30 PM
hey everyone I want to first apologize for this long post but have a few questions which may sound dumb but want to make sure before I finish up this install..
I got the full AAW classic update kit for my 72 Camaro and in the middle of doing the engine/headlight wiring section of the kit.. there is some wires I wont need(horn,heater,ac,wipers) so ill tuck them away or just remove from the kit and for most part rest of the kit is straight forward...
ALTERNATOR:
After removing the old butchered engine harness I found that my alternator has a different connector then what AAW supplies. I will remove the connector and use the one that fits in the alternator
since I have a 1 wire alternator I do not need to use this brown wire correct?
https://static1.pt-content.com/images/pt/2015/10/20151010_1650341_zpshu8wx53a-1.jpg~original (http://s296.photobucket.com/user/408maro1/media/20151010_165034-1_zpshu8wx53a.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/20151010_1707081_zpsuhueyw2f-1.jpg~original (http://s296.photobucket.com/user/408maro1/media/20151010_170708-1_zpsuhueyw2f.jpg.html)
STARTER:
Continuing on with my butchered harness it has 2 of the same color wires going to the starter(which I believe somebody made both the same) one going to the BAT stud and the other was clipped onto this lil side terminal which I believe is the S terminal according to the diagram?
https://static1.pt-content.com/images/pt/2015/10/20151010_1640531_zpskfamrylz-1.jpg~original (http://s296.photobucket.com/user/408maro1/media/20151010_164053-1_zpskfamrylz.jpg.html)
now the instructions state to add the 2 supplied cables in the kit to the BAT stud which seems easy enough, is the purple wire in the diagram going to the small S terminal circled in the previous picture? and the part in this pic I scribbled out I am not to use as this is used for a points ignition?
https://static1.pt-content.com/images/pt/2015/10/20151010_1632441_zpsr69cbx7k-1.jpg~original (http://s296.photobucket.com/user/408maro1/media/20151010_163244-1_zpsr69cbx7k.jpg.html)
VSS:
I have a LT1 style T-56 and have a 2 wire VSS connector I'm going to plug into the trans.. now on the instructions it wants me to use 3 wires total.. any input on this?
https://static1.pt-content.com/images/pt/2015/10/20151010_164555_zpsivzacfot-1.jpg~original (http://s296.photobucket.com/user/408maro1/media/20151010_164555_zpsivzacfot.jpg.html)
https://static1.pt-content.com/images/pt/2015/10/20151010_1632442_zpswchyub4f-1.jpg~original (http://s296.photobucket.com/user/408maro1/media/20151010_163244-2_zpswchyub4f.jpg.html)
IGNITION:
I have a MSD 6AL box and I have the MSD blaster SS which has a -/+ on it. the blaster is connected to the 6AL, the AAW diagram wants me to plug these wires in somewhere for what I believe is tach and ignition? if so where should these go?
https://static1.pt-content.com/images/pt/2015/10/20151010_1632443_zpssyxcxidc-1.jpg~original (http://s296.photobucket.com/user/408maro1/media/20151010_163244-3_zpssyxcxidc.jpg.html)
and lastly I can wire the 12V IGN source from the MSD to a open 12V IGN on the fuse box?
thank you for looking and appreciate any help.. just trying to finish this thing up :confused:
John
ALTERNATOR:
STARTER:
VSS:
IGNITION:
John
