View Full Version : 1972 F-100 Project 4 Kids 4 Projects
Crestronwizard
10-01-2015, 12:58 PM
Hi All. Well, my second child turned 16 so of course we need to build him something. This one wants a real driver. Something for everyday. Starting with a 72 F-100 Short Bed. Getting a Coyote Engine, 4 Speed auto, Coil Over Front, Custom Wheels and a paint job. Don't plan to get too crazy with this one.
Crestronwizard
10-07-2015, 11:15 AM
Drivetrain Arrived
Took the truck apart
Crown Vic Front End to Install
MichaelUser
10-09-2015, 07:35 AM
Drivetrain Arrived
Love it. I will be watching...
Crestronwizard
10-09-2015, 07:45 AM
Thanks. This is the nicest base vehicle I've ever started a personal project on. Kinda weird to not have months of rust repair first. We're trying to have this one done by Christmas, which would make it the fastest project completion too, lol.
HotRod47
10-09-2015, 08:53 AM
I have a 70. They are great trucks, looking forward to your progress.
Boxjohn
10-09-2015, 10:20 AM
interesting.
What 4 speed auto are you going with, how will it bolt up to the Coyote, and is there a reason beyond budget you're going with it instead of a 5 or 6 speed auto?
Crestronwizard
10-09-2015, 11:29 AM
interesting.
It's the 4R70W. Bolts up no problem. There isn't a controller out (yet) for the 6 speed auto. Only a couple of people have made the 6 speed work and I'm not interested in adding the time and complexity to make it work.
Crestronwizard
10-09-2015, 06:34 PM
Crossmember is out. Should have the IFS one in next week and set the drivetrain to see what we're working with.
twosaturns
10-10-2015, 04:34 AM
are you putting a crown vic from end in it?
looking forward to this; I had an '83 F-100 from my father in law when I first got married in '95. always wanted to put a 5.0/T-5 combo in there but funds wouldn't allow it at the time.
Crestronwizard
10-10-2015, 06:50 AM
Yes Crown Vic front and a Lincoln MK 8 IRS should be fun to drive.
Motown 454
10-10-2015, 09:11 AM
Nice clean truck. This should be a fun truck when your done with it.
sdg0080
10-10-2015, 09:39 AM
That will be one hell of a first car... lol should be a great running truck.
Tincup
10-10-2015, 05:48 PM
Very cool....
Crestronwizard
10-14-2015, 11:01 AM
Getting the I.F.S. in place
Alwhite00
10-14-2015, 11:30 AM
Love that style of truck - My dad had a couple back in the day but no short boxes. :( - Keep ub the good work and keep the pics coming.
cbpldc
10-14-2015, 11:42 AM
That will be an interesting beast. Should handle well with proper setup.
Chris
I_make_oil
10-14-2015, 05:15 PM
Great project. subscribed. .
c91x
10-15-2015, 06:32 AM
HP Tuners can now disable PATS... so you could use the stock ECU to control the 6r80
DrFraZZy
10-15-2015, 07:54 AM
Subscribing... Keep posting up the pictures! I have a 1994 f150 lightning.. I want to do this to. I need to find a reliable shop in Maryland that knows what they are doing with IFS crown Victoria swap and how to wire up coyote engine into my truck.
What does it take to get coyote to fit in the CV IFS?
Crestronwizard
10-15-2015, 05:34 PM
I'll know soon :). Looks like if we use the mounts off a 2011-2014 5.0 F-150 then it will bolt up. The Mustang mounts are too wide.
Crestronwizard
10-15-2015, 05:36 PM
Finally!Thats good to know.
cbpldc
10-16-2015, 06:46 AM
Hmm... I never thought about doing something like to my current truck. I've got a pretty minty 82k mile 90 F-150 that I rebuilt the 351 in. I'll be watching closely!
Crestronwizard
10-19-2015, 04:19 AM
Boxed in.
keepat
10-19-2015, 04:46 AM
Great looking truck to start with! Good luck with the build!
Pat
Decurion
10-24-2015, 11:15 AM
I like it! Ive been daydreaming for some time now about a 79 super cab 2wd with a 5.0/6r80 swap. Seems like a low mile truck take-out engine and trans with harness and everything goes for around $6k or so on ebay, which isnt bad for a pretty complete setup. Unfortunately I have way too much going on to do it, so Ill enjoy living vicariously thru you. =D
Crestronwizard
10-26-2015, 06:27 AM
Thanks :). This one has been interesting so far. The Independent Rear stuff arrived today so that's next. I have to figure out the brakes and which A/C unit to run.
Crestronwizard
10-27-2015, 07:57 PM
Test fitting the engine and trans
DrFraZZy
10-28-2015, 03:26 AM
Who one step closer! So it fit like a glove? with the truck engine mount? versus the coyote engine mount one.
Crestronwizard
10-28-2015, 06:24 PM
The truck mounts ended up not working. Used 4.6 mounts. Modifying a 4.6 oil pan to fit. I'll post pics of that once completed.
chunger
10-28-2015, 09:38 PM
Neat project.
Which year Crown Vic front ends fit - I think it might be something like '05 and up, right?
Is that kit you used to tie it onto the trucks frame rails or something you came up with?
Crestronwizard
10-29-2015, 04:05 AM
Neat project.
This is out of a 06. Used the adapters from http://team321.com/truckirs/truckirs.html
brawls43
10-29-2015, 04:54 AM
What did you end up doing for the rear lower control arm mount point? The kit doesn't show if it includes anything.
Crestronwizard
10-29-2015, 04:04 PM
It comes with a plate that matches up with the plate on the end of the rear lower control arm. Those two pieces bolt together. Then it gets welded. We still had to box it in ourselves as it does not fit flush with the frame.
Crestronwizard
11-04-2015, 04:15 PM
The factory 5.0 pan doesn't fit so we got a 4.6 pan and added the necessary bolt holes in the front. Other than those missing, the pan is a perfect fit.
Crestronwizard
11-06-2015, 12:46 PM
More Teardown. Starting on the I.R.S. next.
chunger
11-06-2015, 01:00 PM
Are you using the same vendors kit for the IRS that you did for the front?
How are the instructions?
Crestronwizard
11-06-2015, 01:18 PM
Yes. I'll let you know around Tuesday :)
I_make_oil
11-06-2015, 03:49 PM
The engine looks pretty low in this picture. Would it have caused any problems to have mounted it higher to better clear the frame rails? It's looks like it will be tight to change the alternator and fit the exhaust.
Crestronwizard
11-06-2015, 04:35 PM
Good clearance for the alternator and the exhaust is good now, had to make a little room on the passenger side for the exhaust but that was only because we had boxed the frame. Funny thing is, after doing the mustang I haven't even thought anything was tight on this :).
I_make_oil
11-07-2015, 05:43 AM
Lol I hear that. That engine bay is huge. You should have plenty of room in there.
Crestronwizard
11-07-2015, 04:51 PM
Spring cup installed
Godbolt
11-07-2015, 08:25 PM
Man you've got some lucky sons! Great work.
Dave R
11-08-2015, 07:41 AM
Did the front end kit come with plans? I'm basically wondering because I've seen the install many times in different ways with trucks but no driving results after. The angle's I've seen people put them in at vary and I'd surely expect that would mess with the alignment and driving characteristics. 321 has done well with the rear setup as I've seen that in a few trucks. I just got rid of two IRS's from MkVIII's after deciding not to go that route but whish I would have kept one at least. Did you have to put the truck at ride stance and adjust the front end for angles or did they do that based on your wants for the stance?
The truck looks great and I love the motive. I'm working with my 11 year old now to build something for him and he's pumped. It's good to get them off the games and in the fields and garage. Kudo's to you.
Dave
Crestronwizard
11-08-2015, 09:40 AM
Thanks for the kind words, guys.
The kit is just for being able to bolt in the Crown Vic front. Altering the stance would come from different spindles or springs. Measure twice, cut once.
A lot of parts have arrived. Hoping to make a lot of headway this week. Deadline is Christmas.
nastyn8
11-09-2015, 09:40 AM
Love the project, I will be very interested in what the rear wheel fitment can be, how wide a tire will fit with the IRS?
Crestronwizard
11-09-2015, 09:52 AM
Me too!! I should know by the end of the week.
Crestronwizard
11-09-2015, 09:57 AM
Some Goodies Arrived
20 Gallon Fuel Cell w/ Pump
Shifter
Front Drive Setup for Adding Power Steering
Fuel Rails and Regulator
Steering Column
Crestronwizard
11-09-2015, 03:00 PM
Lots of progress today
Getting the cradle in place
Preparing to weld front mount
Test fitting the Cobra spindles and knuckles
Crestronwizard
11-10-2015, 11:23 AM
Probably going with a little larger wheel, but got it on the ground and rolling :)
DrFraZZy
11-10-2015, 01:29 PM
This truck is taking shape! I can't wait to see it running and driving!
Crestronwizard
11-13-2015, 10:05 AM
Test fitting the bed. These wheels aren't the ones we're running.
Boxed out the firewall. Give us some more room for the A/C unit.
DrFraZZy
11-13-2015, 10:14 AM
I love the color on it already. What are your plans with paint? I hope ur leaving it patina?? It already looks cool the way it is! I know with the right wheels.. You will be breaking necks! LOL
brawls43
11-13-2015, 11:27 AM
^^ I agree with DrFaZZy, would look great with the patina! Plenty of room out back for some big wheels/tires. I love how that engine fits.
Tincup
11-13-2015, 11:52 AM
Nice Job...where did you get that tank?
Crestronwizard
11-13-2015, 04:26 PM
Got the tank off Summit
Plans are currently to paint it but I have considered leaving it alone as(big surprise) have ran over budget.
brawls43
11-13-2015, 05:32 PM
Can always paint it later.
Crestronwizard
11-17-2015, 10:30 AM
Firewall is coming along
Rantheman
11-18-2015, 12:23 PM
This is a very nice project keep up the good work and keep us updated
Crestronwizard
11-28-2015, 10:39 AM
Mounting the tank
JayinMI
11-28-2015, 03:36 PM
This would look even more awesome with a subtle 2-3 top chop. As far as the proportions go, the roof height seems a little off.
Love you work. Are you looking to adopt another "kid?" lol
Jay
Crestronwizard
11-29-2015, 02:16 PM
We'll see what the stance looks like with the bigger wheels.
No more kids! 4 is plenty. Funny thing is I only had 2 when I started the mustang build, lol.
wfo guy
11-29-2015, 03:25 PM
I'm waiting for the drive report! I think I know what you'll have to say but I may be off. :)
Crestronwizard
12-03-2015, 04:07 AM
Some progress. Slowly but surely.
Crestronwizard
12-11-2015, 05:10 PM
Decided to get rid of the drip rails
Munssey
12-11-2015, 08:18 PM
Ah.. a SportCustom, just like the one dad had. Subscribed!
DrFraZZy
01-24-2016, 04:27 PM
How s the truck coming along?
Crestronwizard
01-25-2016, 10:59 AM
Good. In the bodywork phase right now.
Crestronwizard
02-02-2016, 08:12 AM
About to paint the frame and then the truck
- - - Updated - - -
Crestronwizard
02-06-2016, 05:28 PM
Making progress. Bed liner on the frame and firewall. Underside of the cab and bed will be done also. Cleaned up the front crossmember.
injcted
02-06-2016, 06:44 PM
Looking great! Love the project!
Crestronwizard
02-09-2016, 08:29 AM
Engine and front cradle back in
wfo guy
02-09-2016, 05:41 PM
I'm anxious for the drive report. I've owned one of the Cougars that has the rear suspension. I'm aware of what a coyote can do. I don't know what all of it can do at one time. I spent a lot of time in 72 twin i beam trucks. Everything has to be an improvement. :)
migg400
02-09-2016, 06:16 PM
This thing is going to be KILLER!! The Coyote looks right at "home" sitting in there! Good luck with the rest of the build.
Crestronwizard
02-09-2016, 06:47 PM
Thanks :). It's going to be interesting for sure.
Crestronwizard
02-12-2016, 07:09 PM
Made a piece to mount the AC Control into
Measuring to cut in the new defrost vents
Vents cut in. Starting body work on the dash
1965gp
02-14-2016, 10:57 AM
This build is absolutely amazing. I love it!
Crestronwizard
02-22-2016, 01:00 PM
More bodywork on the dash
Bracket for Corbeau Seats
wfo guy
02-22-2016, 04:52 PM
I'm disappointed. I thought I was going to see paint everywhere. :)
Crestronwizard
02-23-2016, 08:38 AM
You would have if we didn't take a week off and go to Lights Out 7 :)
Crestronwizard
02-23-2016, 06:18 PM
Reworked the wiring harness
Test fit some seats I had laying around
twosaturns
02-24-2016, 04:46 AM
haha, I saw your posts on IG and was selfishly thinking "when is he going to get back to work on the truck?" lol
Motown 454
02-24-2016, 07:50 PM
Nice looking seats! Frame came out nice and the motor look Sweet in there!!
MSTSFabbed
02-25-2016, 06:54 AM
What are your test seats out of? I like the look of them.
Progress looks good!
Crestronwizard
02-25-2016, 05:41 PM
They came in the 68 Camaro project that we did. I'm not sure what brand they are. I will check them out and let you know.
Crestronwizard
03-12-2016, 09:14 AM
Time for some Lizard Skin
Crestronwizard
03-14-2016, 07:38 PM
Fuel System Install
Dry Lizard Skin
Tincup
03-15-2016, 04:27 AM
Won't be long now...
migg400
03-17-2016, 10:31 AM
Geoff - Which Lizard Skin did you go with? I was thinking about using it for my build but not sure if you can lay Dynamat on top of it (or if you need to?)
Crestronwizard
03-17-2016, 01:08 PM
Ah, I see now. I got the ceramic one , oops. :)
Crestronwizard
04-21-2016, 07:39 AM
Body work continues..............
Centerforce
04-21-2016, 02:52 PM
We're anxious to see that paint! Everything on this truck looks awesome so far!
Crestronwizard
04-22-2016, 05:31 PM
Need to decide on the color. On a side note, I need a clutch for my Mustang. Going to send you a PM.
Crestronwizard
05-11-2016, 04:55 AM
A little rust repair
Motown 454
05-11-2016, 10:03 AM
The patch looks good.
Crestronwizard
09-15-2016, 07:34 AM
Progress!!
cbpldc
09-15-2016, 10:55 AM
I like that shifter. Looks just like the Lokar unit in my 79 Camaro, but I went with the 10" one.
Chris
Peter Mc Mahon
09-15-2016, 11:48 AM
This is not too far off my truck. I have coyote,4r70w with simple shift, ididit column, aeromotive a1000, MII front end and lizard skin! Whew
Crestronwizard
10-04-2016, 04:43 PM
20" Rushforth Wheels arrived for the truck :)
Tincup
10-05-2016, 03:24 AM
Those are some nice hoops for the truck, what color you going to paint it?
injcted
10-05-2016, 10:03 AM
Cool build! Love these trucks!
2ndroundko
10-05-2016, 04:19 PM
Liking this! Looks like your avoiding scope creep pretty well too.
Crestronwizard
11-15-2016, 08:16 AM
White. No tint, pure as I can get. Toying around with the idea of some grey , light side stripes but I don't know yet
- - - Updated - - -
Thanks. There is a first time for everything, lol
Crestronwizard
11-15-2016, 08:18 AM
Exhaust done.
wfo guy
11-15-2016, 10:16 AM
Cool! I've been waiting for an update, not real patiently. :)
Bossed
11-15-2016, 10:11 PM
Man, I've wondered where you were at on this project. Looks tuff so far, looking forward to seeing it finished.
Crestronwizard
11-16-2016, 07:45 AM
Me too! The doors and hood are being prepped for paint, next week get the cab and bed ready. Shooting for completion by Christmas.
nathankershaw
11-16-2016, 08:35 AM
Nice!
I don't know why...I completely missed the fact that you did the IRS on this.
Looking great!
Crestronwizard
11-16-2016, 04:48 PM
Nice!
Looking great!
Thanks. Hope it works out :)
migg400
11-22-2016, 07:28 PM
Looking Good!!
Crestronwizard
02-08-2017, 10:15 PM
Fitting the panels. Few hours of work and will be ready for paint
sj9ers
02-09-2017, 08:14 AM
Where did you source the brackets for the IRS from?
67cougnut
02-09-2017, 09:29 AM
awesome build!!! Looking forward to the finished product!
blade
02-09-2017, 10:28 AM
Can't wait to see this truck all together! Looking good so far.
Crestronwizard
02-09-2017, 05:08 PM
[email protected]
Crestronwizard
02-09-2017, 05:20 PM
I expect to paint in two weeks............
wfo guy
02-10-2017, 04:02 PM
Did you mention the color choice?
Crestronwizard
02-12-2017, 04:12 PM
Currently bright white. We'll see where it ends up come paint day.
wfo guy
02-13-2017, 09:59 AM
When I was mostly finished with the 51, one of the gentlemen stated: "the color white does nothing to help a vehicle so it better be right." That was a nice compliment and I bet we'll be saying the same thing to you when it's completed. :)
Crestronwizard
02-15-2017, 07:00 PM
Slowly but surely
Crestronwizard
02-20-2017, 03:51 PM
Getting closer. Block it out and see where we're at
Crestronwizard
04-26-2017, 07:35 PM
Bed has been painted. Bed liner next
https://static1.pt-content.com/images/pt/2017/04/izpdsnZwX2-1.jpg
Cab heading to paint
https://static1.pt-content.com/images/pt/2017/04/iPDdFz4R-1.jpg
wfo guy
04-27-2017, 08:33 AM
Cool!
Crestronwizard
05-05-2017, 07:53 PM
Some more paintwork..............
https://static1.pt-content.com/images/pt/2017/05/ivhZWxtdL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/iHgLJw8pL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/iLtM7grJL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/iX5sqJNdL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/is8brbM2L-1.jpg
Bossed
05-06-2017, 05:12 AM
Man, what a cool truck !!
662door
05-06-2017, 09:17 PM
Truck looks great. What white is that?
Crestronwizard
05-07-2017, 06:00 AM
Good question. I said I wanted pure white, no pigment.
Dr G
05-07-2017, 08:59 AM
interesting.
If you study the ratios of the 4R70W vs. the 6R60 or 6R80 you see that it adds a super-short first gear, and then one additional ratio (5th gear) which falls between the 4R70W's 3rd and 4th gears. So really it is a lot of work to add one usable ratio.
The 10R80, now that literally halves the distance between all your gears. That is worth waiting for.
Crestronwizard
05-07-2017, 12:51 PM
That sounds cool............
662door
05-08-2017, 04:43 PM
Haha I did catch that on the last page just wasn't sure if you had settled on an actual brand etc. reason I ask is I'm planning on white for my nova and really like how WHITE this looks in the pics
Crestronwizard
05-08-2017, 07:51 PM
I don't mind sharing. I'll get the paint code this week and post it.
Crestronwizard
05-11-2017, 02:10 PM
Sleet White
- - - Updated - - -
Making her shiny
https://static1.pt-content.com/images/pt/2017/05/imW5tNggL-1.jpg
Crestronwizard
05-15-2017, 05:43 PM
Set the bed on it.
https://static1.pt-content.com/images/pt/2017/05/imdNCX2pL-1.jpg
Crestronwizard
05-21-2017, 07:18 AM
Took an outside pic
https://static1.pt-content.com/images/pt/2017/05/iX6wcQ5cXL-1.jpg
Working on the inner fenders before spraying with bedliner
https://static1.pt-content.com/images/pt/2017/05/idPVDQPkXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/itKMPPrwXL-1.jpg
Retrorider
05-21-2017, 03:25 PM
On where you have the air cleaner at now, are you going to build something around the filter? I live in rural Louisiana where we still have some gravel roads so I was wondering about dust in the inter fender.
Crestronwizard
05-21-2017, 05:30 PM
Yes, It will have a shield
Crestronwizard
05-29-2017, 02:12 PM
Progress!
https://static1.pt-content.com/images/pt/2017/05/igJFhSkQXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/iCXWvRDwXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/ish8knZZXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/iqQ3TB9QXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/iSFvMwLdXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/iNkXrVsqXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/ivwjh7ZvXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/iNkXrVsqX3-1.jpg
andrewb70
05-29-2017, 03:11 PM
Nice progress!
slimjim
05-29-2017, 03:33 PM
The engine bay looks great!
MOREHORSEPOWER
05-29-2017, 03:35 PM
WOW 0-) That is one nice F100 !!!
Crestronwizard
05-30-2017, 04:05 PM
Thanks Everyone. Hood went on today ...............
https://static1.pt-content.com/images/pt/2017/05/iVn8SCjTXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/i4wF4NsjXL-1.jpg
https://static1.pt-content.com/images/pt/2017/05/i9Jg9fdVXL-1.jpg
Rhine
05-31-2017, 04:26 AM
I love this build. I can't believe how clean you got the engine compartment to look. I mean the whole thing is sweet, but that engine compartment blows my mind. I guess it also doesn't hurt that(imho) these 70's fords are probably the best looking trucks ever made. Keep kicking butt.
StarlinerJack
05-31-2017, 01:09 PM
wow this is a great looking truck! Very nice work!
Crestronwizard
05-31-2017, 06:24 PM
Thanks! I am very happy with how that turned out as well. I ran out of room fast underhood of the mustang and it isn't as clean as I wanted. Little more room with this one.
Crestronwizard
05-31-2017, 06:26 PM
Not a lot to show. Third brake light installed. Working on the interior over the next few days. Will post pics soon.
https://static1.pt-content.com/images/pt/2017/06/iPrz2fQCXL-1.jpg
Bossed
06-02-2017, 04:43 AM
Truck looks killer !! Engine compartment is SO clean looking, great job.
Bossed
06-02-2017, 04:59 AM
Crestronwizard
06-14-2017, 10:58 AM
https://static1.pt-content.com/images/pt/2017/06/inztFNkXXL-1.jpg
https://static1.pt-content.com/images/pt/2017/06/it2sC7RkXL-1.jpg
https://static1.pt-content.com/images/pt/2017/06/iHFFTLPmXL-1.jpg
Centerforce
06-16-2017, 10:23 AM
That is one CLEAN engine bay. You did an awesome job, especially considering how notoriously large the Coyotes are. Keep up the great work!
Crestronwizard
07-02-2017, 11:48 AM
Bumpers on. Glass in
https://static1.pt-content.com/images/pt/2017/07/iPzV3whqXL-1.jpg
https://static1.pt-content.com/images/pt/2017/07/iG9RJbnPXL-1.jpg
https://static1.pt-content.com/images/pt/2017/07/i9N43qDBXL-1.jpg
https://static1.pt-content.com/images/pt/2017/07/iB5FzMCDXL-1.jpg
https://static1.pt-content.com/images/pt/2017/07/ikVmzJQVXL-1.jpg
Rhine
07-03-2017, 05:21 PM
Again, this truck is AWESOME. with all of the retro styling coming out on newer vehicles, this is how Ford should bring back the ranger, or resurrect the f100 badge.
nitroracer
07-03-2017, 06:02 PM
Did you make the grill or is that an aftermarket piece? I've never seen one with that pattern before. Truck is looking good!
Crestronwizard
07-04-2017, 01:03 PM
I thought I got it from lmctruck.com Going to look through emails and see :).
Thanks for the kind comments everyone.
Crestronwizard
07-04-2017, 01:06 PM
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=100
The grille inserts
Bossed
07-04-2017, 01:46 PM
Love the truck. The only thing I might would change, would be the bumpers. Maybe chrome or satin silver. Great job !! :twothumbs
JayinMI
07-04-2017, 04:30 PM
I agree with Bossed. Chrome bumper...at least in front. Maybe with shaved bolts. That would do it for me, and I'm not a Ford guy. lol
