View Full Version : Booster pin to MC distance
rohrt
08-11-2015, 07:09 AM
I got my MasterPower check tool and found my pin is ever so slightly engaging the MC. How imperative is the .020 gap? Will this cause the front brakes to drag.
I ground down the pin too much the first time and have a small washer as a spacer behind the MC pin. With the washer out I had way to much gap and a brake pedal that would stop ok but could push to the floor.
https://static1.pt-content.com/images/pt/2015/07/20150711_091237_zps619hewwh-1.jpg
https://static1.pt-content.com/images/pt/2015/08/20150807_143059_zpswsx4ldla-1.jpg
https://static1.pt-content.com/images/pt/2015/08/20150807_143109_zpsi9i8xzba-1.jpg
dontlifttoshift
08-11-2015, 11:22 AM
.020" - .025"
If it is engaging the master cylinder at all, the brakes will drag.
rohrt
08-11-2015, 11:34 AM
Thanks Donny.
I will do some more grinding.
rohrt
08-31-2015, 09:42 AM
Does the O-ring on the booster pin server any function? Is it just to keep the pin from falling out or does it seal anything?
I pulled two pins from junk cars. One was from a 77GP and the other from a 69 Pontiac Catalina. Bother were exactly the same but no O-ring like mine.
