View Full Version : LS bracket question
firebirdzig
06-22-2015, 05:45 PM
Does anyone make a bracket for a DBW pedal in a first gen fbody? Also what about a bracket for the ECM?
Thanks for the help!
Z06vet
06-22-2015, 06:59 PM
DSE makes one for use with a corvette pedal. I just installed one in a 67 im building. Uses 2 bolts on the column bracket to mount it to the firewall, Its inexpensive as well.
Scott
parsonsj
06-22-2015, 07:10 PM
Do all the GM DBW pedals provide the same inputs to the ECM? Can they be swapped without tuning?
andrewb70
06-22-2015, 07:28 PM
The Gen IV pedals are all the same in terms of functionality. So if it has the long 6 pin connector, you're good to go. Common pedals are Corvette, CTSV, and my favorite Monte Carlo SS.
Fourmz
06-26-2015, 06:22 PM
I have been told by CBM Motorsports that fbw pedals are application specific, i.e. If your engine is from a cts you will need a cts pedal, id you have a vette motor you will need a vette pedal. I used the DSE bracket on my GTO pedal and with some minor tweaks it worked like a champ.
icemanrd19
06-26-2015, 06:51 PM
i have the dse bracket. I don't know as far as pedal location goes but it bolts up very nicely and its cheap
terrydmorgan
06-27-2015, 07:16 AM
Good to know. I just ordered one.
csouth
06-27-2015, 02:54 PM
That's incorrect... The programmer just needs to know the pedal you are using when programming the ECM. Andrew's motor is an L92 with a Monte SS pedal. I have a Monte SS Pedal for my TBSS motor. It should only be 24x pedal to 24x motor and 58x to 58x...
icemanrd19
06-27-2015, 08:20 PM
Make sure you have the correct pedal. The dse works with the corvette dbw NOT the camaro. Im going to see what needs to be done so the camaro pedal works.
terrydmorgan
06-28-2015, 05:29 AM
I have the CTS-V pedal. I'll let you know about any mods that are needed
icemanrd19
06-30-2015, 07:01 PM
take a pic of the pedal for me. Ill take one of mine and show you the issue
justanova
07-02-2015, 09:15 AM
http://www.ironworksspeedandkustom.com/index.cfm/page/ptype=results/category_id=2/mode=cat/cat2.htm
they make nice ECM brackets.
nats68
07-07-2015, 08:27 AM
I second the Ironworks bracket. I had to modify it but it's real nice. They have ECM and gas pedal brackets.
terrydmorgan
07-07-2015, 07:26 PM
Here's my CTS-V pedal. And, it fits on the mounting bracket with no modifications.
https://static1.pt-content.com/images/pt/2015/07/C3FEE0D4B799471D8BD125B674BB1FBE-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/14%20Interior/C3FEE0D4-B799-471D-8BD1-25B674BB1FBE.jpg.html)
https://static1.pt-content.com/images/pt/2015/07/1D55C0A45564478EA787F663CAAAD9E5-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/14%20Interior/1D55C0A4-5564-478E-A787-F663CAAAD9E5.jpg.html)
https://static1.pt-content.com/images/pt/2015/07/83207221BEDB40A6B86334F8BE2B4C8B-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/14%20Interior/83207221-BEDB-40A6-B863-34F8BE2B4C8B.jpg.html)
icemanrd19
07-07-2015, 07:52 PM
very nice. Yes my pedal does not. Debating to sell mine and buy the ironworks setup or just make one.
your pedal is offset. Mine is straight down.
terrydmorgan
07-11-2015, 08:05 AM
Thanks for the tip. My bracket arrived today. Should have it in the car pretty quickly.
https://static1.pt-content.com/images/pt/2015/07/288C540AF71D4D58957604372CB4CD87-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Chris%201969%20Camaro/288C540A-F71D-4D58-9576-04372CB4CD87.jpg.html)
Motown 454
07-11-2015, 07:54 PM
My pedal that came with my LSA crate motor doesn't fit the DSE bracket. I bought one and I'll have to make something anyway because of the different pedal mount. To me it looks like the Iron Works bracket is the one for my pedal it bolts from the side not front to back like Terry's
csouth
07-27-2015, 08:22 PM
I welded studs to the floor..... Just a thought
icemanrd19
07-28-2015, 03:34 PM
isn't there a epoxy or something that someone is using to "glue" fab bosses to a finished firewall?
