    Results 1 to 10 of 10
      Nov 2012
      Gainesville,GA
      Why are my floor pans getting so hot?
      1979 Camaro sbc350 Long tube headers 2.5in exhaust.
      I've recently got my car on the road and after driving for 10-15 minutes the floor pans are unbelievably hot. My girlfriend can barely keep her feet on them when wearing sandles.
      Now, I have rattle trap (dyna mat) throughout interior and double layered on passenger side, and recently wrap my exhaust under the floorpans with header wrap. There isn't much of a difference with that. My exhaust isn't super close to the pans either they're probaby 3-4 inches away.
      Any ideas? I guess make a heat shield would help put.
      Sep 2010
      Beach Park IL
      No carpet or insulation? _____mat type products do not really help much for heat.
      Donny
      Nov 2012
      Gainesville,GA
      I haven't installed the carpet yet. But I have no insulation. Ill buy some insulation if it will really make a difference but it gets HOT in chere! I figured the mat would do good against heat but I guess not.
      Pflugerville, TX
      Also check your timing to make sure it's not retarded too much which can cause high egt.
      Sep 2010
      Beach Park IL
      Insulation and carpet will help tremendously. I have used and been very happy with Under Carpet Lite from DEI https://www.designengineering.com/ca...er-carpet-lite
      Donny
      Nov 2012
      Gainesville,GA
      Never thought about timing and I will check out that insulation. Thanks for the ideas Gentlemen.
      Oct 2011
      I sprayed the bottom of my car with lizard skin ceramic coating
      Dynamat itself does nothing to reject heat
      Dynamat has a product called Dynaliner which I have used before with great results
      Dynaliner installs directly over Dynamat and molds easily into place
      No adhesive
      I will be using Dynaliner for my floor pans
      Feb 2014
      Georgia
      B-Quiet Ultimate works good as a sound deadener and heat suppressor and it's cheaper than DynaMat.
      Steve - 1970 Roadrunner
      Sep 2010
      Beach Park IL
      I used to use dynaliner. The UnderCarpet is easier to work with, less money, more efficient, and doesn't collapse under my heel and leave a permanent dimple in the carpet.
      Donny
      Not a big Fan of Header Wrap - it will rot out your Headers Fast! Jet-Hot Coatings is my choice!
