    Results 1 to 7 of 7
      Jun 2015
      69 camaro with 5th gen wheels
      I had these left over from another project. I had to mill out the inner wheel about 30thousands to make them fit. I'm Actually selling the wheels just wanted to see how they looked.
      What do you guy's think?
      May 2015
      They look good, car looks great, but the wheel bolt pattern is off a bit. Same bolt pattern as BMW wheels.
      I believe they are 5x120.65, and the older Camaro's & all Corvettes are 5x120
      Jun 2015
      I came up with about .025" difference, I don't think it would be a problem if someone wanted to use this combo. I also milled just enough so the hub would be exactly centered on the wheels, you just have to center the lugs and tighten them evenly
      Dec 2008
      Detroit
      Quote Originally Posted by mean buzzen half dozen View Post
      You have that backwards... The '69 would be 5x120.65 more commonly known as 5x4.75. The Gen 5 wheels would be 5x120.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Dec 2008
      Detroit
      Quote Originally Posted by mattscamaro View Post
      The style is fine, they are just too big for a car that size.
      Chris--
      May 2015
      Quote Originally Posted by csouth View Post
      I got the numbers correct, just forgot which way they went.
      Sep 2011
      Southern Ontario
      I like the wheels and the car but the wheels are way too big on there.
