Results 1 to 2 of 2
05-11-2015 #1
- Join Date
- Jan 2008
- Posts
- 87
What do I have to do to use a flat center cap? and c5 brakes ... Help pls
Hey guys, question, the rear I think is fine but on the front wheels (custom) 19x9 would do I have to do to avoid using a pretending center cap... I want to use a flat center cap like newer cars do... The rotor/hub bearing or whatever you call it sticks out a bloody 2.75" front the hub...
What is the simplest/cheapest solution?
i think if I change front brakes to c5 brakes I could solve this issue ... But figured to see if anything else can be done.
If if nothing else can be done, are the c5 brakes going to change my backspacing? I got a 5" bs on 19x9 rim. cheers
05-12-2015 #2This is a problem faced by many, but this starts with ordering the wheels from he start. If you order a large mounting pad the wheels
will bury the dust cap in the wheel allowing a flat cap. We work with our customers and assist them with this when ordering. If you already have the wheels it might be impossible.
