View Full Version : Hotchkis problems???
hotrodneb
05-11-2015, 03:47 PM
This JUST doesn't seem to be sitting right......Looks too low in the front and too high in the back
It all is supposed to be Hotchkis lowering springs front/rear.......but I think I got took. I will be looking to see if someone cut the front coil when I get home. Opinions please
Front---Is this about where a hotchkis lowered spring sits? or is it lower??
Rear--Doesn't this look about stock height?? or is this about where a lowered multi-leaf from them sits??
https://www.pro-touring.com/attachment.php?attachmentid=112656&stc=1
kochevy67
05-11-2015, 05:32 PM
You left out some important info. What motor is in the car, and did you buy the springs used or new?
hotrodneb
05-11-2015, 05:51 PM
yuppp that might help
LS-1 bought all the springs here I think from couple different sellers....not new but not used. Certainly Hotchkis has a number stamped on them somewhere. I will look when I get home. Also bought some coil spring spacers off ebay. I already have isolators installed top and bottom on both coils. That didn't help the front ride height much.
ccmc
05-11-2015, 06:45 PM
What size are your tires?
Mine sits about like that but my rear looks a little lower.
My front looks like that and I have a 245/45-17 tire in front 275/40-17 rear
chocthunder
05-11-2015, 08:38 PM
I have Hotchkis on my 69 Camaro. My front looks like yours but my rear is lower. I have 3 inch drop front and rear. Could you have a 3 inch drop in the front and a 2 inch drop in the rear?
Hotchkis
05-11-2015, 09:11 PM
Here is a Z-28 we just finished at the shop. It's got bigs and littles, so it's got a bit of rake, but you can see the gapping using the rim for reference.
If you need any help ID'ing the parts, feel free to give us a call!
https://static1.pt-content.com/images/pt/2015/05/2015050620115527_zpsienoc5wb-1.jpg (http://s304.photobucket.com/user/HotchkisPerf/media/2015-05-06%2011.55.27_zpsienoc5wb.jpg.html)
JakeD
05-11-2015, 10:46 PM
Is this the 2" drop or 3" drop. You guys aren't very good at clarifying that.
Gil
05-11-2015, 11:25 PM
Hotchkis lowering springs...'74 Nova housing with 8.5" Eaton Posi....LS1 brakes.....and a cheap-o rear sway bar
97359
@ hotrodneb,
If I may : just unbolt your rear sway bar to see if the rear stance change then retighten with wheels on the ground
Gil
hotrodneb
05-12-2015, 04:00 AM
Wheels are 17s F/R Tires are all 225-40ish-17 all around, and btw I am sticking to same-sized tires F/R
Just guessing from comments and pics I would guess I have 2" F/R......Maybe my spacers will get the front closer.
I wouldn't mind a little rake, but this seems a bit much for my taste.
rickpaw
05-12-2015, 06:14 AM
Did you tighten the rear suspension before the car had a chance to settle down with all the components (fuel tank/seats/glass, etc...). Stock or drop spindles?
Here's a picture of my 67 with similar set up (2" Hotchkis front/1.5" leaf rear). Engine is 5.3 truck.
https://static1.pt-content.com/images/pt/2014/08/DSC_0969_zps92b3846e-1.jpg (http://s616.photobucket.com/user/rickpaw/media/67%20Firebird%20LS%20swap/DSC_0969_zps92b3846e.jpg.html)
Hotchkis
05-12-2015, 07:58 AM
Sorry about that, 2" front (1907F) and 1.5" Rear (2407C). If you need any help with spring ID PLEASE call us!
JakeD
05-12-2015, 09:30 AM
Nice that looks good! How do you like the ride? I am considering the TVS kit or RideTech coilovers/4link. Any advice?
See: https://www.pro-touring.com/threads/115120-67-Firebird-In-Need-Of-Suspension-HOTCHKIS-vs-RIDETECH
hotrodneb
05-18-2015, 07:48 AM
Thinking I solved my own problem, I have just a slight rake left and am comfortable with that. I'm thinking a bit more sidewall might be in order. The tires on it now are just scabs.
112968
I used a pair of these....from Eckler's (coil spring spacer)
112969
