goob8869
05-10-2015, 07:53 PM
I have a 67 Camaro with a ls6 in it with autometer gauges. After about 6 to 7 min after starting the gauge is reading around 250. I changed tstat and checked water pump both was working fine so I shot the tstat housing and heads with a laser temp gun and it read 100 at tstat and 110 at heads. Is this a sending unit, gauge problem, or something else. The gauges and sending unit are practically new. Any help much appreciated
Schwartz Performance
05-10-2015, 08:05 PM
Could be either the sending unit or gauge. Replace the sending unit and narrow it down.
Unfortunately new stuff isn't always perfect!
-Dale
sgernon
05-11-2015, 04:22 AM
I had the same issue with an oil temp gauge on my car. It was reading 60+ degrees off from the reading using a laser on the oil thermo. I changed the sender but it didn't fix the issue. I finally swapped the whole gauge and now it reads as it should. I bet your gauge has an issue.
