    Results 1 to 19 of 19
      Nov 2011
      Livermore, CA
      Okay tiny brake line tutorial, who has one?! Looking for tips, tricks (6" lines)
      As I've said over and over again i'm not very artistic and I think one has to be semi in order to create flowing brake lines. Right now however I'm just working on MC to prop valve so 6" at the most.
      I have the flaring thing down, so far that seems to be okay (proper tools and various web tips). Bending I'm using a few things that provide decent clean bends, but still struggling. Now there may be nothing I can do but trial and error, but figured I would ask if there are tricks to this.
      I already bent one where I felt it was right and then noticed well I can't flare the end and put an end on it, so had to straighten it again. Now I'm just massaging it because it feels like it wants to go but it's getting tugged taught by one of my angles
      So any tricks you learned over the years, i would love to make squared off ones, but they all become kind of rounded ..
      Also I'm not using steel lines, so it should be that much easier.
      Tory
      Livermore, CA
      American:
      1966 Chevelle SS "Tribute" Retro / Pro-Tour
      For Sale
      Oregon
      Depending on the bending and flaring tools you're using, you'll need to allow for enough tube to either fit the dies of the flaring tool or the dies of the bending tool. There are bending pliers that can allow you to make tighter radius bends, closer to fittings, or you can use other mandrels to help with bending, but in the end it comes down to practice and planning.
      Is that copper/nickel brake tubing? That should help make things easier than steel or stainless steel...I'm thinking it must be since you said that you straightened a bend. I generally use a roller die bender on the easy to get to bends, and then I have a mandrel with various diameters to help with the others where I wrap the Ni-Copp line around it by hand.
      In looking at the the short piece with two bends that you're trying to make, you can always extend the line a little further out from the MC to allow for room for both the flaring die and the bending tool, whatever it may be.
      Tobin
      KORE3
      It's what I does.
      One thing most tubing design guys like me (HVAC in my case) do is to put a third, usually minor, bend between the two bends shown in your image. With only 2 bends, both bends need to be dead nuts or the fitting will be out of square and tough to start. A third bend in plane will 'unfold' or 'fold' and let the fitting start square.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Nov 2011
      Livermore, CA
      Yep Copper, pretty easy to bend but bend well is another issue. I've got a bending tool but I think it sucks, or I just flat out don't know how to use it..
      uugh lost my post.
      Anyways just starting to practice a bit more using different objects (and my bender)..
      So I replaced the front MC to prop this evening after a bit of playing around. I think it looks better, I'll tackle the rear one tomorrow as i'm getting a bit more comfortable but I can see this taking some time to sink in
      Secondimage is this evening after redoing the front one, the first image is what it looked like before, not a ton of difference but for some reason to me the first looks better (shrug!!) at least it appears to line up better and the pipe is not at a weird angle.
      The rear one I may do something similar to the front.. well feeling a bit better but have a long way to go.
      Tory
      Last edited by cactuss4; 05-11-2015 at 07:49 AM. Reason: picture wrong description
      Livermore, CA
      American:
      For Sale
      Sep 2011
      Southern Ontario
      What about adding a coil [loop] ? I think that looks better in this situation and it allows a lot of wiggle room.
      Nov 2011
      Livermore, CA
      Quote Originally Posted by Peter Mc Mahon View Post
      I thought about that actually and found a couple of videos on it. I was trying to determine if it was really worth it and how exactly i would to that with so little space to work with.
      Livermore, CA
      American:
      For Sale
      Mountain Springs, Texas
      That one bend looks a little tight in the pic. I am not sure I would leave that one unless it is just the photo angle.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2011
      Livermore, CA
      Quote Originally Posted by dhutton View Post
      Don
      Thanks for looking, I checked it, it's the picture only. It's picking up the black of the inner fender and making it look bad. It's the same circumference around that entire bend
      Tory
      Livermore, CA
      American:
      For Sale
      One useful trick is to mock up your lines with a piece of 1/8 rod or even coat hanger. Then you just copy what you have with the brake tubing.
      Don
      Central CA USA
      I have a pair of vise grip pliers with tube bend dies welded into the jaws. Works great to bend in tight places. My main rule is to make the lines long if possible. As you found out, length is needed for the bender & the fittings need to be aligned perfectly straight to allow them to screw together. More length allows easier alignment without kinking the lines. Any line running from master cyl to chassis should have a couple of loops, or at least some length & two or more 90 degree bends.
      Feb 2013
      South Carolina
      Quote Originally Posted by David Pozzi View Post
      Is this due to vibration/movement between the body and frame?
      May 2013
      qld Australia
      Country Flag: Australia
      i use a bit of welding wire to make my lines up first then make it out of brake line so they are all good and the right length. that way i can use my straight piece of tube and put my 2 fittings on, then bend it after.
      Mopar or no Car
      Your either with us or Behind us
      Oct 2007
      Shawnee, KS
      I am also using the NiCopp line. I used a piece of 12ga electrical wire out of Romex as my pattern. The only problem I've found with the NiCopp is getting the soft copper to seal properly at a flared connection. For instance, Over the pumpkin of the rearend where both hard lines meet the hose. Not sure if I'm over tightening or not enough. The double flare looks great, just soft. Good luck with yours. On my lines on the very short runs, I went straight down out of the master then turned towards the back of the car for an inch then turned towards the proportioning valve. The extra bend made it easier to make and install.
      Shannon
      67 Camaro - Finally getting to BUILD it.
      Camaro Build -> HERE
      Our Drag boat blog and videos HERE
      Apr 2007
      Previous shop built my rear axle with a loop on top of the rear axle (I know WTF.. did they not have a flaring tool?). Car had a severe driveline vibration when first built, and I was young and stupid and it was my only car. A summer with lots of miles that way and the loop on top of the rear axle vibrated until it broke at the base where it curled up away from the rear axle housing. Single circuit brakes and I am very lucky to still be here to tell about it.
      So I'm not really keen on coils in hardlines. I know it's a bit of an apples to oranges comparision, but... Hmmm.
      At the M/c if you say so... I have seen that OE, I admit...
      Nov 2011
      Livermore, CA
      Well I think i'm starting to get the hang of it, have started using a few different tools that I had around the garage and that seem to be making things a bit easier, as well as getting a better idea.
      Livermore, CA
      American:
      For Sale
      Feb 2013
      South Carolina
      Looks better than the factory GM coils I had at the MC.
      Oregon
      Quote Originally Posted by cactuss4 View Post
      Practice makes perfect...looking much better.
      Tobin
      KORE3
      It's what I does.
      Nov 2011
      Livermore, CA
      Thanks guys, it is starting to click a bit that's for sure!
      Tory
      Livermore, CA
      American:
      For Sale
      Southern Indiana
      I have a pair of these but got them from Matco dealer http://m.summitracing.com/parts/lil-...leSwitchTablet
      http://www.summitracing.com/parts/li...q38aAsJd8P8HAQ
      And want these, also have two hand benders for larger lines that are 180 deg benders
      I also use a Mastercool hydraulic flaring tool. It has dies for inverted flare, bubble flare, Ford/GM quick connect, and older gm fuel filter flares.
      Also made good deal on bad tool from Snap on dealer and got 37deg an flaring dies also.
      Lee Abel
      AFTERMARKET PERFORMANCE
