    Results 1 to 4 of 4
      Feb 2006
      San Diego, CA
      Thread in wheel studs and Kore3 Brakes???
      Is anyone using the thread-in 1/2"-20 ARP wheel studs with their Kore3 Big Brake kits (or just using them period)?
      If so, have you had any issue with the stud loosening when installing/tightening/torqueing the lug nuts?
      I've ordered my Kore3 GMSS 325mm C6 big brake kit and I opted to upgrade to the thread-in ARP 1/2"-20 wheel studs for the hubs. . .I chose the 1/2"-20 thread-in studs because they were the largest diameter studs for the hubs.
      Now I'm getting ready to machine bolt-on wheel spacers for my C4 ZR-1 wheels and I'm wondering if I want to use thread-in wheel studs or press-in studs for the wheel/spacer assembly. . .just curious if anyone has had any issues with these thread-in studs. . .
      Thanks!
      '67 Pontiac Firebird 400 RA
      http://www.lateral-g.net/forums/showthread.php4?t=7693
      '97 Camaro
      '00 Yamaha R6
      '01 Aprilia RS-50
      '02 Yamaha R1
      Feb 2006
      San Diego, CA
      I guess I should add that my car is being built mainly for track use. . .
      '97 Camaro
      '00 Yamaha R6
      '01 Aprilia RS-50
      '02 Yamaha R1
      Apr 2012
      Woodstock, IL
      We use them all the time and haven't had that issue. You can put some blue Loctite on them (only just under the head) and make sure you've got a little anti-seize on the lug nut end after installed.
      -Dale
      SchwartzPerformance
      Feb 2006
      San Diego, CA
      Thanks for the input so far. . .I figured I would use some blue LocTite. . .
      '97 Camaro
      '00 Yamaha R6
      '01 Aprilia RS-50
      '02 Yamaha R1
