    Results 1 to 2 of 2
      wayne nj
      wilwood adjustable brake valve question
      I have a 72 cutlass w/ factory m/c and booster. I am in the process of installing ls1 rear disk brakes. Where is everyone mounting the valve for easy installation, use and which valve part number are you guys using? If anybody has pics of their install that would help. Thanks again.
      Feb 2013
      South Carolina
      This might be your easiest solution: http://www.wilwood.com/MasterCylinde...emno=260-13190
      It's what I have but no idea if the lines would work for an OE MC though.
      I might otherwise fabricate a bracket to mount where the old distribution block went and put it there with the bolt through version:
      http://www.wilwood.com/MasterCylinde...emno=260-12627
