    Results 1 to 4 of 4
      wayne nj
      ls1 disc to 72 cutlass bop rear brakes
      Can anyone in detail tell me what's involved to make this work ? Booster,master cylinder, lines etc.The search function only shows c clip rear conversions. Any help would be appreciated.
      Sep 2004
      Kettering, OH
      I detailed my conversion here (front and back): http://1967firebird.atwebpages.com/chassis2.php Should give you enough info to do yours.
      1967 Firebird Convert, Fuel Injected 462 ci, TKO 600
      wayne nj
      Thanks for the input. Very nice fab work on those brackets. Any chance you would be willing to whip up those bearing retainers for a small fee? does anyone else have anything to add specific to an a-body BOP conversion? Such as brake lines, ebrake cables and m/c choices. My current set up includes C5 front brakes and the factory 11" booster and disc /drum m/c. Thanks!
      Sep 2004
      Kettering, OH
      Thanks. You can download the cad files from my page and send them to a laser cutter and they should be ready to go when you get them back. If you use the other bracket in my setup, you'll have most of your e-brake problem solved.
