Results 1 to 4 of 4
- Join Date
- Feb 2006
- Location
- San Diego, CA
- Posts
- 166
Affordable 15/16" manual master cylinder to fit a first-gen F-body???
I'm upgrading the front brakes on my '67 Firebird 400 coupe (manual brakes) to the Kore3 GMSS C5/C6 325mm kit and I need to install a new master cylinder as well; I would like to run a 15/16" master cylinder after talking with Tobin via email. . .
. . .problem is, I don't want to spend a couple hundred bucks on a master cylinder that I'm not going to use anymore once I get around to upgrading the rear brakes. I'm not planning on upgrading the rear brakes until I upgrade the rear axle though. I don't wanna buy a BOP rear big brake kit from Kore3 only to have to replace most of it when I swap the rear end out for a 9".
Does anyone know of an OEM 15/16" bore master cylinder that has a bolt pattern to fit a first-gen F-body???
Thanks!
'67 Pontiac Firebird 400 RA
http://www.lateral-g.net/forums/showthread.php4?t=7693
'97 Camaro
'00 Yamaha R6
'01 Aprilia RS-50
'02 Yamaha R1
