    Results 1 to 2 of 2
      Feb 2013
      South Carolina
      Brake line routing on 69 GM B body with Wilwood MC/prop valve?
      Still working on the disc brake install on this Impala. Rear hard lines are finally run and correctly sized so I'm on to the new master cylinder. I have the Wilwood kit with a proportioning valve and bracket (the one with a built in pressure diff switch). Looking at my current factory setup, I have the MC with the rear line feeding into the proportioning valve, and then both front and rear lines feeding to a distribution block that has a pressure switch.
      Am I correct in thinking the Wilwood assembly replaces everything and the brake lines coming out of the prop valve just go straight on to the front/rear brake lines?
      Jun 2012
      Yes
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
