Results 1 to 8 of 8
10-17-2005 #1
Backspacing w/ 93-97 f-body rear brakes
I made a post before about getting a set of centerline wheels, the rear backspacing would be 5.5inches with a 17x9.5 wheel. If I switch to the discs from a 93-97 f-body do I need to add another .25" to my backspacing? 5.75 instead of 5.5?
Also, this may be asking too much, but if I do the front C5 conversion OR the b-body 12" conversion w/ 1LE rotors does anyone know if they change the spacing in the front?
Thanks for any help in advance.
10-17-2005 #2
- Join Date
- Feb 2005
- Location
- Jacksonville, NC
- Posts
- 208
I would like to know the exact same answers to these questions. This is for a first gen camaro correct?
Derek
10-17-2005 #3Oops crap. Its for a 74 camaro actually. It should have the same effect though I would think.
10-18-2005 #4
- Join Date
- Feb 2005
- Location
- Jacksonville, NC
- Posts
- 208
Yes it would have the same effect, and actually the rear backspacing sounds almost the same if not exactly alike.
10-18-2005 #5Well what I've gathered from other threads and PM's you need to add 1/4" of backspacing when converting to discs. So for me, instead of 5.5" I need 5.75". Hope it helps you.
10-18-2005 #6
