View Full Version : Wire size for Alternator
cwylie
04-07-2015, 08:00 AM
What size wire should I run off my 140amp alternator to the battery? 4 awg?
dontlifttoshift
04-07-2015, 08:42 AM
Distance?
1989GTA
04-07-2015, 09:34 AM
4 gauge should work. That is what I am running on my 160 amp alternator.
H2Ogbodies
04-07-2015, 10:37 AM
Unless its relocated to the rear, there's no need for such a large charge wire directly off the alternator to the battery. A better option is a remote junction with the 4ga supply from the alternator. Then, run a 10ga from junction to battery for charging. All other accessories/relay banks, etc. as well as your remote voltage sense wire run off that same junction as well. Hopefully this isnt a 1-wire alternator you're using.....?
