View Full Version : 1969 camaro/firebird backspace
69firebird19
04-06-2015, 12:12 AM
Would a 4.5 backspace work on the front with 2 inch lowered springs on 18 wheel
chocthunder
04-06-2015, 10:32 AM
Depends in how wide of a tire you want to use.
69firebird19
04-06-2015, 02:28 PM
18 by 8 wheel.. 245 40 18 tire
69firebird19
04-06-2015, 02:29 PM
Rear is 18 by 9 with a 5.25 backspace. 275 40 18 tire
69firebird19
Will that rear backspace work aswhell?
chocthunder
04-06-2015, 05:21 PM
Not sure if that will work without rubbing in front. I have a 69 Camaro and I plan to use 235/35/18 on front with 18x8 with 4.5 BS and 265/35/18 on rear with 18x9 with 5.25 BS on rear. I'm going a little conservative on tire size.
You need 4 and 3/4 backspace. I'm running 245/45-17 on 17x8 with 4-3/4 backspace on my 69 Camaro. Slight touch on the frame rail on the inside tire at full lock
Quikbrd
04-06-2015, 06:21 PM
Yes, it should work, key word is should. All of these cars are a little different, what fits one may fit another a bit differently, no computer helping put these cars together, and in 46 years since they were assembled, "**** happens"
That being said, my 69 Bird is running 17X9 on all four corners (4 7/8 backspacing) 255/40 in front / 275/40 in rear, the right side front tire touching the frame in a full crank autocross situation, but it's not hurting anything. Measure, then measure again, when you think you it's gonna fit, purchase and then deal with what you got, good luck!
69firebird19
04-06-2015, 09:28 PM
I think im going with a 4.75 backspace front since i tought they only offered a 4.5 backspace so a 9 wide with 5.25 backspace is right 3 inchs lowered rear
69LSX
04-07-2015, 05:04 AM
On my 69 Camaro I'm running 245/40's on 18 x 8 w/ 4.75 BS (front) and 275/40's on 18 x 9.5 w/ 5.5 BS (rear). 2" drop front & rear.
67rally
04-07-2015, 06:39 AM
4.5" BS would push the wheel out 1/4" more than yours and lessen the chance of rubbing on the subframe.
Thank you, I know but then I would be into the fender and I seldom hit full lock except in parking lots at low speed
