View Full Version : DSE second gen lower arm bolt size
gray86hach
03-01-2015, 05:12 PM
I will be ordering DSE lowers for my second gen camaro next week but I need to get new bolts for them.
Stock is 14mm I think early cars were 9/16.
I would like to get the 9/16 if that is what the arms are set up for
Anyone know?
Tim
gray86hach
03-07-2015, 05:40 AM
Dse told me 14mm. Got the arms and the bolt is kind of sloppy in the bushing. Going to pick up 9/16 today.
Tim
Skip Fix
03-07-2015, 06:21 AM
Early cars were 1/2". 9/16 fit in most frames-used them in my 79. My 81 TA they fit in 3 of four holes but the slightly thicker neck portion would not in that one so to be consistent I just ordered 10.9 14mm a little longer to use hardened washers.
Global arms come with sleeves to fit both 1/2 or 9/16-14mm for their bushings.
NOT A TA
03-07-2015, 06:27 AM
Early 2nd gens were 1/2", later ones are 14mm. Are you using the shouldered bolts? These are the two sizes used stock.
https://static1.pt-content.com/images/pt/2015/03/006_zps35680ae1-1.jpg (http://s240.photobucket.com/user/NOTATA/media/The%2014%20Car%20Performance%20Therapy/006_zps35680ae1.jpg.html)
gray86hach
03-07-2015, 07:14 PM
Yes I had the stock bolts and they were sloppy in the bushings. Bought new 14mm they were the same. The 9/16 fit tighter.
Mocked everything up today. Going to pull it apart next week and antisieze the bolts install the springs.
Tim
