    Results 1 to 5 of 5
      Mobile, Al
      Who makes a booster to fit 81 Camaro m.c.!??
      Everyone seems to think that their 11" booster fits 70-81 Camaros... but they don't. I have a new Delco alum master cyl that I want to use in my '71 but the Tuff Stuff booster hole is too small. Who carries a new booster made for an '81?? I have called just about everyone!
      May 2002
      Northern California
      does the booster not fit the firewall or the master that you have doesnt fit the booster? can you post a picture of the problem areas? Part number for the master too if you have it.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mobile, Al
      The diameter of the mount hole in the booster for the master cyl is too small... by a long shot. AC Delco part # for master is 18M172 (1981 Camaro). The 81 is different because it is the first year for the aluminum body w/plastic resevoir. The booster center hole has to be 2". The previous was about 1-11/16"
      Jun 2006
      Katy,TX
      I know they have one for the 81 TA 4 WD but it is a dual diaphragm that give more assist-why they decreased pedal ratio on those cars. I had to replace the one on the 81 TA a few years ago.
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Jun 2012
      Have you looked at a later model tuff stuff ones.
      I have one i can measure up and compare to the stock one on my 79
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
