    Results 1 to 6 of 6
      Mar 2013
      Pittsburgh, PA
      1986 Elcamino 480HP LS Crate Engine- Looking for A/C Compressor -Which One should I
      1986 Elcamino 480HP LS Crate Engine- Looking for A/C Compressor -Which One should I go with and why??? I will be using the Corvette front set up, less the A/C.
      1. LS A/C Accessory Drive Bracket - Passenger’s Side Bracket Only (A/C) - Fits Sanden SD508 or SD7 Comp. PART# 20-134
      2. LS A/C Accessory Drive Bracket - Passenger's Side A/C Bracket - works with R4 compressor PART# 20-133
      So there are 3 different compressors!!
      1. Sanden SD508
      2. SD7 Comp.
      3. R4 Compressor
      Thanks RW
      On my 65 elco, using a factory evap, I'm using a 508 w/ this mount and drive
      http://www.vintageair.com/lschevycompbrktdownloads.asp
      Reasons: cleaner front of engine, universal availability of e 508 pump, large enough pump to support a factory evap (compared to an SD7), and a more robust and versatile pump than an R4 (refrigerant selection, mounting orientation,and durability
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Apr 2012
      Woodstock, IL
      The 508 has more capacity than the SD7- 138cc vs 100cc.
      However the SD7 is more compact and since the displacement is smaller it can likely hold up to higher sustained rpm.. Don't quote me on that part though.
      I don't know anything about the R4.
      -Dale
      SchwartzPerformance
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      R4 is 10 cubic inches (about 160cc.) Again, if you are running the factory A/C system, the SD7 may be performance limited, particularly at lower engine speeds.
      Might want to look at pulley drive ratios, while considering a programming change to cut the compressor at higher engine rpm.
      Greg Fast
      1984 el Camino
      Jacksonville, FL
      Didn't those el caminos come with the R4s?
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Mar 2013
      Pittsburgh, PA
      Quote Originally Posted by 130fe View Post
      You would be correct!!
