View Full Version : Booster recommendation
bad86ss
02-22-2015, 09:55 AM
I have an 86 Monte with the stock 12" SINGLE diaphragm booster which is very weak.
I have 13" c5 fronts and 12" LS1 rear disc. Most Montes had a 9" dual diaphragm booster and some people recommended the 12" dual from a caprice.
Any advice on which route to go? I have a vacuum canister laying around, my pedal was super stiff with that on there
Nicks67GTO
02-22-2015, 10:17 AM
I have the Kore3 C6 fronts and LS1 rears and I went with Tobin's recommendation which was a 9" Dual diaphragm booster, and 1" master cylinder. I got my booster and brackets from TuffStuff and my master cylinder is a 1" bore Right Hand drive 2002 S10 unit. About $50 bucks on amazon. I used the adjustable Wilwood proportioning valve/ bracket and made my own lines.
https://static1.pt-content.com/images/pt/2015/02/20141116_143003_zpsnwx5nc4y-1.jpg (http://s239.photobucket.com/user/novaguy73/media/Brakes/20141116_143003_zpsnwx5nc4y.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/20141116_143015_zpsxpqjmlhb-1.jpg (http://s239.photobucket.com/user/novaguy73/media/Brakes/20141116_143015_zpsxpqjmlhb.jpg.html)
bad86ss
02-22-2015, 11:32 AM
I need to get a proportioning valve too.
How does the pedal feel with the 9"?
gray86hach
02-22-2015, 11:37 AM
I am going to use that same set up on my camaro with c6 brakes. Should have it together in the next couple months.
Tim
69L48Z27
02-23-2015, 06:16 PM
X2 on Nicks67GTO Recommendation. Have the same setup with 14" and 13" Wilwoods.
130fe
02-23-2015, 07:05 PM
I have the exact same setup on my Kore3 C5 front and rear. I have the DSE setup (same as Nicks but cheaper LOL) Works great! The prop valve was very easy to tune and get right.
aps63
02-23-2015, 08:03 PM
I have been running that same setup for the last 2 years, works great.
bad86ss
02-27-2015, 08:06 PM
Well, I ordered a 9" dual diaphragm booster and im hoping it's bad out of the box. The pedal presses very softly and returns very slow.....so slow I can't pump the brakes
Nicks67GTO
02-27-2015, 10:32 PM
Who did you get it from? Did you change master cylinders too?
bad86ss
02-28-2015, 02:36 PM
Got it from advance. The master cylinder was replaced a few months ago
bad86ss
02-28-2015, 05:41 PM
Booster is a reman CARDONE and the master cylinder is a 15/16 bore from a 79 Riviera.
Even with the brake booster not hooked up, the pedal stroke seems longer than I want too
