View Full Version : corvette accessories
firebirdzig
02-20-2015, 06:54 PM
If you run the 04 style corvette accessories do you have to run the power steering fluid cooler or can you run it like an older car where it goes
From the steering box straight to the power steering pump?
130fe
02-20-2015, 08:19 PM
You can run it without the PS cooler, works great.
firebirdzig
02-20-2015, 10:18 PM
Awesome thanks!
130fe
02-21-2015, 05:38 AM
Something to consider is what kind of line are you going to be using for the high pressure side? If you are going to use a AN6 style line, consider purchasing the fitting DSE sells that allows you to install that line without interference with the pulley. It makes installation easier.
