View Full Version : 70 cougar reborn
coup2vert
01-27-2015, 11:45 PM
The underbody was painted along with engine bay all to the body color ford Maroon. Some rust repair with a twist on rear lower 1/4 where they rend to rott out instead of using paych panel I used stainless steel on inner and outer on the bottom 6 inches did the same on the doors lower corners and also trunk lower corners.Rear suspension reinforcement brackets were bolted on after paint .
andrewb70
01-28-2015, 04:45 AM
Nice! What's with all the cougar builds all of a sudden?
67cougnut
01-28-2015, 09:51 AM
I've been telling everyone for the last 15 years, these will become popular! and low and behold!
CAT69
01-28-2015, 11:11 AM
Looking good!
And keep the cougar threads coming...reading through them all is getting me motivated to start tearing down the '69 that's been sitting in the garage for the past year.
andrewb70: Your '67 build thread was a damn good read!
andrewb70
01-28-2015, 11:28 AM
Thanks! I've been having fun with the build.
coup2vert
01-28-2015, 05:28 PM
I've been lurking in the shadows for a while my build started in 2011 im just starting to document everything and load all my pics hope to have car on the road by summer
coup2vert
01-28-2015, 09:58 PM
I did a heidts front suspension then decided to change to coilover but not mount points so more fabwork needed and ended up with 2.25id coilovers with multi height adjustable .Also noticed air intake tube hole was too low had to raise it up to clear the wheel more welding and painting
coup2vert
02-01-2015, 09:45 AM
4link setup for that protouring cougar look and function With the front end done time to setup rear diff and get welding done I had setup the car on my Wedge Clamp frame straightening equipment and was able to use the measuring tools and square up the diff and locate the brackets that had to be welded.I stayed with the ford 9" just added 3.5 posi also added rear sway bar and disc brakes.
coup2vert
02-01-2015, 10:17 AM
Getting the right stance was a chore I wanted the car to have a certain look I wanted to slam it at first but realized it wouldn't be practical since I plan to using it as a DD and if you look at the car on the side you notice the bottom of rocker panel sits quite high visually because of the way car was built frame rails and convertible seat supports sits much lower to the ground so I ending up setting the front crossmember at 6"
